Re: SR20DET into 1200 Coupe Project
From Little Rock, AR
Here's how everything has worked for me. Originally I had stock 1200 front struts. I went to test fit new wheels like 6 years ago and found a set of front wheel drive offset wheels that I liked a lot (lots of negative offset though...not sure how much exactly). I found that with the stock 1200 struts I would need lots of spacers to keep the wheels from rubbing on the strut.
A couple days later I installed the B310 front suspension, and went back and test fit (and bought) those same wheels...only now with the B310 suspension it didn't require any spacers and it all just barely tucked inside the fenders and didn't rub the strut....so I guess I had it backwards.....the B310 struts gave the widest track (the hubs stuck out further).
Using the same FWD wheels, I installed the 280ZX struts onto the B310 steering arms/control arms, and now I need to run about 23mm of spacers on each side to keep the wheel from rubbing the strut. So the 280ZX struts are much like the stock 1200's track width....I never measured exactly how much the stock 1200 is, but I could find out by trying to bolt one of those wheels onto a stock 1200 strut I have and see how much spacer I need to keep it from rubbing the strut.
I wonder if you could turn down the thickness of the hub (the mounting face) a little bit to bring the track closer. As long as there's enough meat for the lugs to mount into I think you could.
Well, hope this helps!
Posted on: 2005/5/28 16:06
Subject Poster Date
     SR20DET into 1200 Coupe Project AFRacer 2004/2/25 15:45
       Re: Finally my SR20 project is on it's way! matbighat 2004/2/25 17:20
         Re: Finally my SR20 project is on it's way! Astro_Boy 2004/2/25 22:26
           Re: Finally my SR20 project is on it's way! AFRacer 2004/3/12 12:03
             Re: Finally my SR20 project is on it's way! AFRacer 2004/3/17 9:44
               Re: Finally my SR20 project is on it's way! AFRacer 2004/3/22 14:13
                 Re: Finally my SR20 project is on it's way! muke 2004/3/22 14:42
                   Re: Finally my SR20 project is on it's way! Team_Dat 2004/3/23 1:19
                     Re: Finally my SR20 project is on it's way! 1200rallycar 2004/3/23 9:57
                       Re: Finally my SR20 project is on it's way! AFRacer 2004/3/23 14:07
                         Re: Finally my SR20 project is on it's way! 1200rallycar 2004/3/23 14:24
                           Re: Finally my SR20 project is on it's way! AFRacer 2004/5/2 5:18
                             Re: Finally my SR20 project is on it's way! AFRacer 2004/5/4 12:57
                               Re: Finally my SR20 project is on it's way! AFRacer 2004/5/8 10:06
                                 Re: Finally my SR20 project is on it's way! AFRacer 2004/5/9 14:51
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/11 12:24
         Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/15 9:42
           Re: SR20DET into 1200 Coupe Project dattodevil 2004/5/15 10:01
             Re: SR20DET into 1200 Coupe Project ang94541 2004/5/15 19:29
               Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/15 23:01
                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/30 8:53
                   Re: SR20DET into 1200 Coupe Project belgian_roadster 2004/5/30 17:39
                     Re: SR20DET into 1200 Coupe Project matbighat 2004/5/31 1:01
                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/1 15:30
                       Re: SR20DET into 1200 Coupe Project matbighat 2004/6/1 18:17
                         Re: SR20DET into 1200 Coupe Project belgian_roadster 2004/6/3 19:58
                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/7 2:28
                 Re: SR20DET into 1200 Coupe Project mperdue 2004/9/20 19:22
                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/9/23 14:08
                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/1 16:28
                       Re: SR20DET into 1200 Coupe Project 2332owner 2004/10/1 17:50
                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 6:22
                           Re: SR20DET into 1200 Coupe Project 2332owner 2004/10/2 9:21
                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 10:26
                               Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 10:52
                                 Re: SR20DET into 1200 Coupe Project ca18det_man 2004/10/2 11:32
                                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 13:51
                                 Re: SR20DET into 1200 Coupe Project ddgonzal 2004/10/3 3:56
                                   Re: SR20DET into 1200 Coupe Project 1200rallycar 2004/10/3 5:31
                                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/4 9:03
                                       Re: SR20DET into 1200 Coupe Project ca18det_man 2004/10/6 12:50
                                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/17 12:20
                                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/23 3:25
                                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/31 12:47
                                               Re: SR20DET into 1200 Coupe Project woodydat 2004/10/31 13:18
                                                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/31 22:02
                                                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/7 1:53
                                                     Re: SR20DET into 1200 Coupe Project dattodude 2004/11/7 3:06
                                                       Re: SR20DET into 1200 Coupe Project phunkdoktaspok 2004/11/7 4:49
                                                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/7 13:34
                                                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/13 9:39
                                                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/14 9:52
                                                               Re: SR20DET into 1200 Coupe Project ddgonzal 2004/11/14 21:13
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/16 11:07
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/20 9:52
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/20 10:15
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/20 13:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/21 1:31
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/21 11:34
        Re: SR20DET into 1200 Coupe Project kegs 2004/12/21 19:59
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/22 0:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/22 1:36
        Re: SR20DET into 1200 Coupe Project aleks 2004/12/22 4:10
        Re: SR20DET into 1200 Coupe Project datsuncr 2004/12/22 19:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/1/2 23:36
        Re: SR20DET into 1200 Coupe Project BACKFIRE 2005/1/3 0:10
        hello anser 2005/4/1 1:17
        Re: hello NIS15L 2005/4/1 2:00
        Re: hello LAGWAGON 2005/4/1 2:06
        Re: hello dattodevil 2005/4/1 8:03
        Re: hello tom210 2005/4/1 10:12
        Re: hello Demojob 2005/4/1 12:49
        Re: engine mounts Puls8r 2005/4/1 13:18
        Re: engine mounts dattodevil 2005/4/1 13:29
        Front suspension brakes Puls8r 2005/4/1 13:52
        Re: Front suspension brakes 2332owner 2005/4/1 14:04
        Re: Front suspension brakes AFRacer 2005/4/14 12:50
        Re: Front suspension brakes AFRacer 2005/4/17 13:38
        Re: Front suspension brakes LAGWAGON 2005/4/17 15:02
        Cost? AFRacer 2005/4/17 15:26
        Re: Cost? dattodude 2005/4/17 22:43
        Driving impressions AFRacer 2005/4/21 14:51
        Re: Driving impressions AFRacer 2005/4/21 15:18
        Re: Driving impressions Quicksand 2005/4/21 19:09
        Re: Driving impressions AFRacer 2005/4/23 19:18
        Re: Driving impressions dattodude 2005/4/24 0:29
        SR20DET into 1200 Coupe Project AFRacer 2005/4/24 12:57
        Re: SR20DET into 1200 Coupe Project dattodude 2005/4/24 13:50
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 4:55
        Re: SR20DET into 1200 Coupe Project LAGWAGON 2005/4/26 5:34
        Re: SR20DET into 1200 Coupe Project B120dat 2005/4/26 7:22
        Re: SR20DET into 1200 Coupe Project datrat_dave 2005/4/26 9:04
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 9:34
        Re: SR20DET into 1200 Coupe Project Demojob 2005/4/26 12:38
        Re: SR20DET into 1200 Coupe Project converted 2005/4/26 12:51
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 13:53
        Re: SR20DET into 1200 Coupe Project converted 2005/4/26 13:58
        Re: SR20DET into 1200 Coupe Project 2332owner 2005/4/26 16:25
                                                       hello anser 2005/4/1 1:15
                           Re: SR20DET into 1200 Coupe Project tom210 2005/4/4 8:34
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/1 14:19
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/13 9:10
       Re: SR20DET into 1200 Coupe Project mad120y 2004/6/16 9:23
         Re: SR20DET into 1200 Coupe Project converted 2004/6/16 9:36
           Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/19 6:22
             Re: SR20DET into 1200 Coupe Project AFRacer 2004/7/23 1:22
               Re: SR20DET into 1200 Coupe Project ang94541 2004/7/23 7:55
                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/8/11 6:06
                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/9/20 16:35
       Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/27 16:57
         Re: SR20DET into 1200 Coupe Project killer1200 2005/4/27 17:20
           Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/28 14:22
             Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/30 15:40
               Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/8 15:19
                 Re: SR20DET into 1200 Coupe Project datrat_dave 2005/5/9 12:54
                   Re: SR20DET into 1200 Coupe Project dattodude 2005/5/9 22:54
                     Re: SR20DET into 1200 Coupe Project datrat_dave 2005/5/10 13:52
               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/27 6:10
                 Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/27 17:19
                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 3:59
                     Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 4:28
                       Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/28 16:06
                         Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/28 16:32
                           Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 17:59
                             Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/29 4:36
                               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/3 6:02
                                 Re: SR20DET into 1200 Coupe Project 1200rallycar 2005/6/3 8:25
                                 Re: SR20DET into 1200 Coupe Project phunkdoktaspok 2005/6/3 8:54
                                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/4 4:27
                                 Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/3 9:55
                                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/4 4:24
                                     Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/6 16:34
                                       Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/6 19:32
                                         Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/7 17:02
                                           Re: SR20DET into 1200 Coupe Project converted 2005/6/8 2:14
                                             Re: SR20DET into 1200 Coupe Project twistex 2005/7/4 10:19
                                               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/6 3:37
                                                 Re: SR20DET into 1200 Coupe Project twistex 2005/7/6 7:25
                                                   Re: SR20DET into 1200 Coupe Project AFRacer 2005/7/22 2:26
                                                     Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/25 2:04
                                                       Re: SR20DET into 1200 Coupe Project AFRacer 2005/7/27 22:18
                                                         Re: SR20DET into 1200 Coupe Project MRSR1200 2005/7/31 12:20
                                                           Re: SR20DET into 1200 Coupe Project converted 2005/7/31 12:29
                                                           Re: SR20DET into 1200 Coupe Project b310gx 2005/8/1 2:21
                                                             Re: SR20DET into 1200 Coupe Project tappet 2005/8/1 3:55
                                                               Re: SR20DET into 1200 Coupe Project MRSR1200 2005/8/1 5:50
                                                           Re: SR20DET into 1200 Coupe Project prodat 2005/9/16 7:56
                                                             Re: SR20DET into 1200 Coupe Project dattodude 2007/5/6 22:29
                                                         Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/8/2 5:33
                                                           Re: SR20DET into 1200 Coupe Project AFRacer 2005/9/15 10:08
                                                             Re: SR20DET into 1200 Coupe Project liam_1200_coupe_deluxe 2007/5/8 1:50
                                                               Re: SR20DET into 1200 Coupe Project converted 2007/5/8 2:26
        Re: SR20DET into 1200 Coupe Project tappet 2007/5/8 12:01
                                                               Re: SR20DET into 1200 Coupe Project 1200post 2007/5/19 13:06
        Re: SR20DET into 1200 Coupe Project Mildman 2007/5/19 13:26
                                           Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/6 3:27
                         Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 17:50
       Re: SR20DET into 1200 Coupe Project AFRacer 2009/4/12 0:02
         Re: SR20DET into 1200 Coupe Project dattodude 2009/4/12 0:20
           Re: SR20DET into 1200 Coupe Project datsa73 2009/4/12 16:50
