Browsing this Thread:
1 Anonymous Users
Re: Suitable stering wheel for 1200 ute |
From Melbourne, VIC
The standard wheel is not very dished so you're not going to get much more reach out of a flat wheel. Smaller is certainly better as then you can at least get your legs under the wheel without rubbing all the time. You can comfortably go as small as 13 inches as the steering is still quite light, even with larger tyres.
Just take note that the flatter the sterring wheel is, the closer the rim gets to your indicator stalk. Bumping the idicators on every time you turn the wheel is a real PITA.
Posted on: 2005/6/21 6:03
