Re: compression ratio calculations- does anybody know how to do it
From Taupo New Zealand
as for the compression test idea...
although it is a nice idea, it falls down because the inlet valve is still open when the piston is well on it's way up the bore. So by the time the pressure in the cylinder starts to increase the volume is already much less than the swept volume. Maybe if you knew the exact cam timing of the valves opening and closing (not at .050" like cam specs are usually quoted at) you could work out where the piston is when compression starts, and then the volume at that point.
Then you can use simultaneous equations to solve the unswept volume bit.
Brain hurting yet? Basically it's a whole lot of maths and a little bit of physics to work out something that probably just isn't worth it... I would just rip the head off....
Posted on: 2005/9/7 12:27
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Subject Poster Date
     compression ratio calculations- does anybody know how to do it datsunb120 2005/9/5 12:46
       Re: compression ratio calculations- does anybody know how to do it Psych 2005/9/5 12:51
         Re: compression ratio calculations- does anybody know how to do it dattodevil 2005/9/5 12:58
           Re: compression ratio calculations- does anybody know how to do it dattodevil 2005/9/5 13:00
             Re: compression ratio calculations- does anybody know how to do it Psych 2005/9/5 13:13
               Re: compression ratio calculations- does anybody know how to do it selaga 2005/9/6 6:04
       Re: compression ratio calculations- does anybody know how to do it pro240c 2005/9/6 7:02
         Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/6 13:09
           Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/6 15:11
             Re: compression ratio calculations- does anybody know how to do it mperdue 2005/9/6 23:40
               Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/7 2:25
                 Re: compression ratio calculations- does anybody know how to do it mperdue 2005/9/7 5:20
                   Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/7 5:43
                     Re: compression ratio calculations- does anybody know how to do it mperdue 2005/9/7 5:50
                       Re: compression ratio calculations- does anybody know how to do it 1200coupe 2005/9/7 6:14
                         Re: compression ratio calculations- does anybody know how to do it nzdatman 2005/9/7 12:05
                           Re: compression ratio calculations- does anybody know how to do it nzdatman 2005/9/7 12:27
                             Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/8 8:54
                               Re: compression ratio calculations- does anybody know how to do it nzdatman 2005/9/8 12:38
                                 Re: compression ratio calculations- does anybody know how to do it Grunterhunter 2005/9/9 3:52
