Re: 0-100km times ???
From brisbane
Yes, BA Falcons are heavy but they will still cut a mid 15 second quarter mile two up which is quite quick for a family sedan. Anyway, I was just using that as an example. Also, keep in mind how understressed the LS2's are.
I suggested the atmo CA for budget reasons. Obviously you could upgrade to the turbo motor later if funds permit. The mods to fit the atmo CA aren't insurmountable nor expensive and the actual cost of the motor and gearbox will be much cheaper than what you could build an A series that would produce similar power levels for. In addition to this the CA will be a nicer thing to drive due to the extra cubes and factory nature.
Anyway, it's all food for thought. But if the reason why you want to fit a new motor is to beat 8's and WRXs then you will need more than 120rwhp.
Regards Matty
p.s. Dats-hot - excellent advice mate.
Posted on: 2006/1/29 14:20
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Subject Poster Date
     0-100km times ??? pager 2006/1/28 4:58
       Re: 0-100km times ??? 2QK4U 2006/1/28 5:28
         Re: 0-100km times ??? pager 2006/1/28 5:58
           Re: 0-100km times ??? 1200rallycar 2006/1/28 23:50
             Re: 0-100km times ??? ddgonzal 2006/1/29 0:16
               Re: 0-100km times ??? lidder 2006/1/29 4:29
                 Re: 0-100km times ??? COUP1200 2006/1/29 4:53
                   Re: 0-100km times ??? datto1200mad 2006/1/29 6:26
                     Re: 0-100km times ??? pepper 2006/1/29 6:32
                     Re: 0-100km times ??? rb20 2006/1/29 6:36
                       Re: 0-100km times ??? matty 2006/1/29 9:44
                         Re: 0-100km times ??? pager 2006/1/29 11:37
                           Re: 0-100km times ??? matty 2006/1/29 14:20
                             Re: 0-100km times ??? dazzasute 2006/1/29 16:02
                             Re: 0-100km times ??? Ash 2006/1/30 1:55
                               Re: 0-100km times ??? matty 2006/1/30 4:54
                                 Re: 0-100km times ??? 1200rallycar 2006/1/30 7:09
                                   Re: 0-100km times ??? matty 2006/1/30 8:35
                                     Re: 0-100km times ??? MadTimo 2006/1/30 12:51
                                       Re: 0-100km times ??? L18_B110 2006/1/30 12:56
                                         Re: 0-100km times ??? Cable_Tie 2006/1/30 22:20
                                           Re: 0-100km times ??? BigV 2006/1/31 1:22
                                             Re: 0-100km times ??? Cable_Tie 2006/1/31 1:42
                                               Re: 0-100km times ??? Demojob 2006/1/31 2:44
                                                 Re: 0-100km times ??? matty 2006/1/31 3:29
                                                   Re: 0-100km times ??? 1200rallycar 2006/1/31 6:55
                                                     Re: 0-100km times ??? L18_B110 2006/1/31 9:26
                                                       Re: 0-100km times ??? Dodgeman 2006/1/31 11:12
                                                         Re: 0-100km times ??? L18_B110 2006/2/1 0:00
                                                           Re: What chew torquin' 'bout ??? Cable_Tie 2006/2/1 1:30
                                         Re: 0-100km times ??? 1200rallycar 2006/1/31 7:10
                                   Re: 0-100km times ??? pager 2006/2/1 3:47
                     Re: 0-100km times ??? Dats-hot 2006/1/29 13:06
       Re: 0-100km times ??? datsik 2006/4/11 16:49
         Re: 0-100km times ??? SLAM1024 2006/4/12 0:31
