( HELP ) Hitachi carb question
Not too shy to talk
OK today I was installing my new wheels and tires and go to start my car and notice that there's a huge fuel leak coming from under the car so I immediately turn it off and try to find the spot where it's coming from.
Here I find these 2 lines attached by zipties and 1 line is leaking.
The other picture indicate were the lines are coming from.
Any help would be greatly appreciated.
jpg  IMG_0191.JPG (144.19 KB)
16110_4f0cdfeb632d8.jpg 550X734 px
jpg  IMG_0186.JPG (160.43 KB)
16110_4f0ce0373c109.jpg 664X386 px
Posted on: 2012/1/11 1:00
Re: ( HELP ) Hitachi carb question
Those are the twin carb overflow lines. The carbs are not supposed to overflow, but if the do, that's what the lines are for.
Did you just change the fuel pump? If so it's probably too high of pressure for carburetors. Carbs, including Webers like 3psi fuel pressure.
Posted on: 2012/1/11 2:50
Not too shy to talk
The one that's overflowing is the one closest to the radiator, the only thing I did was install new air filters.
I think the float is stuck, now how would i fix the float?
Posted on: 2012/1/11 3:19
Use a 3/8 socket extension of a pair of pliers. Rap on it medium strength right here on top center of the float bowl:
Float bowl: right side of photo
If that doesn't stop it, undo the 4 bolts and remove the top and inspect it.
Posted on: 2012/1/11 3:26
Does your engine has the flat-top carbs (A12T) or round-top carbs (A12 GX)?
float blow Top looks like this, pretty much the same as a downdraft carb. It uses the exact same fuel inlet valve as the single carb unit.
Posted on: 2012/1/11 3:29
Here's the brass float. Shake it, if it feels like fuel is inside then it probably has a hole in it and sinks too far to cut off the fuel
Posted on: 2012/1/11 3:33
Not too shy to talk
It has a A12 GX carbs
Posted on: 2012/1/11 3:49
Not too shy to talk
Found the problem, the float in the front carb is at the bottom and full of gas, now wherr would I buy a rebuild kit or just the float.
Posted on: 2012/1/11 17:27
You can either repair it, or purchase a replacement float which is $13 from Nissan. See Float repair.
Posted on: 2012/1/11 22:47
Not too shy to talk
Thank you sir u were very helpful.
Ordered a new one from Nissan but in the meantime a Datsun friend is letting me barrow a new one till the one I ordered gets here.
Posted on: 2012/1/12 0:13
