Re: Rear Drum Brake Adjustment
From Brisbane
if I adjust the adjuster to the max and then remove the drum, it will be hard to remove the drum.
if ever I get the drums off it will be impossible to put it back by adding one extra click to the adjuster
Very sure the adjuster is not fitted upside down (double checked that as well)
I might take a photo of my drums and also when the cable is pulled to show the toggle lever and link movement
Posted on: 2006/5/17 9:14
Subject Poster Date
     Rear Drum Brake Adjustment Razor 2006/5/15 23:24
       Re: Rear Drum Brake Adjustment ratdat_uk 2006/5/16 1:30
         Re: Rear Drum Brake Adjustment Razor 2006/5/16 1:48
           Re: Rear Drum Brake Adjustment ratdat_uk 2006/5/16 2:05
             Re: Rear Drum Brake Adjustment Razor 2006/5/16 3:47
               Re: Rear Drum Brake Adjustment Razor 2006/5/16 3:48
               Re: Rear Drum Brake Adjustment B210sleeper 2006/5/16 3:52
                 Re: Rear Drum Brake Adjustment Razor 2006/5/16 3:54
                   Re: Rear Drum Brake Adjustment B210sleeper 2006/5/16 3:58
                     Re: Rear Drum Brake Adjustment Razor 2006/5/16 4:00
                       Re: Rear Drum Brake Adjustment B210sleeper 2006/5/16 4:06
                         Re: Rear Drum Brake Adjustment Razor 2006/5/16 4:17
                         Re: Rear Drum Brake Adjustment 1200coupe 2006/5/16 4:24
                           Re: Rear Drum Brake Adjustment Razor 2006/5/16 4:30
                             Re: Rear Drum Brake Adjustment Razor 2006/5/17 7:39
                               Re: Rear Drum Brake Adjustment benny 2006/5/17 7:57
                                 Re: Rear Drum Brake Adjustment Razor 2006/5/17 9:14
