what is this thing? how to connect? (written "ETi200")
hi all,
this thing is at my car last time i got A12,
which the previous owner (my dad) install it.
but when i transplant to A15, it is not connected..
i post the picture i taken.
anyone knows how to connect this thing?
what is this thing anyway?
i have ask my dad but he cant recall what it is.
there is 4 wire comes out from it, blue, yellow, green and black,
i assume that black is ground,
the rest i not sure.
anyone can teach me please?
thanks in advance.
Posted on: 2006/7/25 1:54
Re: what is this thing? how to connect? (written "ETi200")
From Christchurch. NZ
What does it say on the case?
Posted on: 2006/7/25 7:14
its written
"ETi200"
"Electronic Ignition"
with small words
"automotive Electronics Ltd,
made in England"
there r 2 LED there, red and green
red one labeled as "Timing"
green one labeled as "Ign on"
beside the LED are vertical words
"12V Negative Earth"
on the other end is a 3 way switch,
, able to switch to:
"standard","off","electronic"
the smaller word
Posted on: 2006/7/25 7:55
sam1741 wrote:
its written
"ETi200"
with small words
made in England"
the smaller word
Dude, sounds like you got yourself a CDI system. Capacitive Discharge Ignition.
Posted on: 2006/7/25 9:18
Posted on: 2006/7/25 9:28
Love your Datsun.
Treat it well.
anyone knows the color code?
i cant get that figure out
except the black i know is ground...
Posted on: 2006/7/25 9:55
throw it out and fit an electronic distributor!
Posted on: 2006/7/25 11:43
oh,
i do have electronic distributor
is it not needed after changing from contact to electronic dizzy?
Posted on: 2006/7/26 1:00
I doubt if it is a CDI, those are usually thicker.
It looks like a regular electronic ignition module.
Black usually goes to the distributor points, blue to the coil, yellow or red to tachometer, and that leaves green to power (but green is not common). But it might be totally different and wiring it incorrectly could damage it. Does it have any markings on the back or near the wires?
My advice: Don't use it, just use the stock setup until you can find wiring diagram. Nissan electronic distributors use a different type of control box from what I've seen.
Posted on: 2006/7/26 5:32
the other side is totally blank, nothing written...
Posted on: 2006/7/26 7:36
