best performance idea for A15 before turbo
From sydney, northen beaches!
hey just wondering whats next step for my A15, i got extractors, su carbs. and was needing more power! is Porting a option. cheers
Posted on: 2007/4/11 9:22
Re: best performance idea for A15 before turbo
From Melbourne, Australia
thermo fan is cheap and easy
porting is expensive, for potentially low power boost
maybe change diff ratio or gearbox?
electronic distributor
Posted on: 2007/4/11 9:27
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
do you have a budget?
Posted on: 2007/4/11 10:04
From sydney
Cam.
Posted on: 2007/4/11 10:16
From Adelaide, Australia
i recon A15 wid A14 head. single side draught webber good exhaust and electronic dizzy. easy cheap and reliable
Posted on: 2007/4/11 10:36
From Gold Coast
Weld a tow hook to the front and get a ca ute to tow you.
Posted on: 2007/4/11 12:52
From Bunbury Western Australia
cam (depending if you plan to go turbo later) with new competition valve springs and reradiused lifters, high compression pistons ie; flat tops (also depending on if you want to go turbo later on if so then save your money for forgies) head work is good for making power later on for example if you did head work on a stock A12 you may get 5% increse in power but if you had a fully worked A15 you would get a heap of power just from the head work releasing all that power meaning the engine will only put out as much power as the head can flow
Posted on: 2007/4/11 13:04
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Tamworth, NSW
I thoughr a15 had bigger ports than a14
Posted on: 2007/4/11 13:09
Project coupe:
Just drive it
nah a14 and A15 heads are exactly the same
Posted on: 2007/4/11 13:14
cheers for thee help. i am on bit of a budget, but i like the idea of the cam. how gain is possible
Posted on: 2007/4/11 13:18
(1) 2 3 »
