Re: Fuel line.....fuel setup....... questions/advice
i was going to run a standard vl fuel pump.
3/8 in 5/16 out.(cant change fittings.)
so should i run 5/16 from efi pump to fuel reg and 3/8 from there to the rail???
or
piss pump off and get 1 with 3/8 in and out.
i am looking for a rissing rate reg maybee malpasi
or a el cheepo 1 off ebay.
Posted on: 2007/8/12 22:56
From SE Melbourne
I think 5/16" should really feed the engine well enough. So I don't think you need to change at this point.
I've actually been told that using the 044 might be a bit too much overkill and just heat up the fuel....but I'm committed now and we'll see.
I rather have too much than not enough.
VL and 5/16 should be plenty though,
Posted on: 2007/8/12 23:00
Mildman, Datsunless
think ill just leave it 4 now...
is it ok just to run normal efi hose up the tunnel or next to chassis rail INSIDE.
i want to get cheep hose as i will prob upgrade later
wheres the safest LEGAL way
Posted on: 2007/8/12 23:11
From SE Melbourne
I don't think running rubber hose through the cabin will be OK.
I'm not even sure in a road car if steel fuel line in the cabin is OK.
On a race car it's OK, that's what I'm building....if your going to engineer it you might need to check with an engineer....as I don't know if it is legal for a road car!
Posted on: 2007/8/12 23:14
Mildman, Datsunless
through the tunnel.....?????????
not through the car.....
the orig goes through tunnel
but it will be hard to screw clamps in there
then it has to fit rear brake line aswell
Posted on: 2007/8/12 23:17
From SE Melbourne
Ah ok - sorry was thinking through the cabin.
Even in the tunnel I'd be using steel fuel line, you wouldn't want to nick the rubber on some tree branch or something and end up with fuel pissing out at 6bar.....
Posted on: 2007/8/12 23:26
Mildman, Datsunless
where can i purchase hard line from or in a coil.....????????????????????
bunnings have pipe benders and clamps.
they have copper pipe there but is to big in diameter and not sure bout copper lines...
Posted on: 2007/8/13 20:00
From Melbourne, Australia
just to clear up.... steel fuel line (covered for its protection) through the cabin is fine as long as there is no connections anywhere in the cabin
i bought fuel line from pirtek... if you know the length you want they will flare the ends for you (i measured the stock pipe roughly with a tape measure and it worked out fine for me)
and you can bend it up by hand without a problem
so no tools required for that
use the stock line as a return pipe
Posted on: 2007/8/13 20:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Quite a regular
What did they flog it for per meter? Im miles away from even having to worry about this im still working out if It'll fit! but would be a good resource to come back to if there were some figures thrown around.
Posted on: 2007/8/13 21:46
was trying to remember but can't really
think it was between $30-50 for 3/8 from back of coupe (fuel tank under back) to engine bay
but i could be miles off
im sure it wasn't uber expensive, i remember thinking it wast too bad
Posted on: 2007/8/13 21:48
1200 Coupe Rallycar
« 1 (2) 3 »
