Re: Wanted - Weber & Manifold suit A15 in Aus
Good explanation. Another thing to add is that the size doesn't indicate how much air the carb flows. 32/36, 38, or 42 is just the size of the throttle bore. What's more telling is the venturi size. The sidedrafts are advertised with certain sizes ("42s" will widely vary in venturi size). The downdraft Weber/Holley also can have different size venturis, but not always advertised as such. A stock 1200 probably works best with smaller venturis, a racing 1200 would like bigger venturis. If they are too big, the fuel economy and low-speed hp can suffer.
Posted on: 2003/4/13 18:39
Subject Poster Date
     Wanted - Weber & Manifold suit A15 in Aus Buff 2003/4/11 2:40
       Re: Wanted - Weber & Manifold suit A15 in Aus Lobster 2003/4/11 10:35
         Re: Wanted - Weber & Manifold suit A15 in Aus 1200rallycar 2003/4/11 10:45
           Re: Wanted - Weber & Manifold suit A15 in Aus dimlight65 2003/4/11 16:33
             Re: Wanted - Weber & Manifold suit A15 in Aus 1200rallycar 2003/4/13 5:32
               Re: Wanted - Weber & Manifold suit A15 in Aus 1200ute8u1 2003/4/13 6:25
                 Re: Wanted - Weber & Manifold suit A15 in Aus jaimecidpedro 2003/4/13 8:11
                   Re: Wanted - Weber & Manifold suit A15 in Aus ddgonzal 2003/4/13 18:39
           Re: Wanted - Weber & Manifold suit A15 in Aus 89mm 2003/4/15 8:23
