does the 120y swaybar clear the ca18det sump. . MINE Doesnt? help
From Newcastle
as the name sugests my 120y swaybar in me 1200 ute isnt going to clear the sump on the ca is their a way around this?
Posted on: 2007/10/28 9:35
Re: does the 120y swaybar clear the ca18det sump. . MINE Doesnt? help
hey laney
try maddat they sell a Adjustable 22mm swaybar that will clear the ca motor
Posted on: 2007/10/28 10:29
From Warwick, QLD
no they don't clear it but using a hammer you can neatly manipulate the sump so it fits
Posted on: 2007/10/28 10:33
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Newcastle
are you serious lol a hammer ay can u do that lol
Posted on: 2007/10/28 10:52
From Newcastle
bump
Posted on: 2007/10/28 23:14
From Adelaide, SA
i wouldnt hit the sump with a hammer, scott from maddat in the process of making custom ones look into that.
Posted on: 2007/10/29 6:13
I've been looking into an upgrade myself.
The avenue I'm going down is modifying a 1inch R31 skyline swaybar. It only needs narrowing by about 3-4 inches and the extra width can be bent into the lower part to clear the sump. The lengths from the chassis mount to the pin ends are spot on.
Posted on: 2007/10/29 7:32
From SE Melbourne
What crossmember are you using?
My swaybar clears the sump (in a 1200 coupe though).
I've got a crossmember put together by Andrew - maybe his mounts slightly further back.
Posted on: 2007/10/30 2:24
Mildman, Datsunless
From Newcastle
i think it would be slightly higher i got maddat engine mounts. .
Posted on: 2007/10/30 2:32
From SE Melbourne
EDIT: Pics
Mildman, Datsunless
(1) 2 3 »
