Re: 1200 coupe race suspension setup?
From Ballarat Victoria
Hi Jared, Are the rear springs the standard coupe springs apart from the eyes being reversed? or have you added leaves?
Are the kumo`s convetional or radial slicks? (Radials need to run alot more camber than 2 degs. more like 4.5.)
What tire pressure are you running?
What brand/valveing on rear dampers?
Does the diff have any lateral locating device?
Does the rear end have suficient travell? (you need min 3"droop and 4" bump with a live axel, thats 7" overall)
I`d try adding at least 2 degrees more camber and a little more toe out (about 4mm total) at the front.
The rear could be caused by insuficient droop travel on suspension/dampers, serverly under inflated rear tires (if the condition exists only with steering input) or exesive rebound on rear dampers.
Simon.
Posted on: 2008/5/7 3:53
VIC DYNO HIRE
Subject Poster Date
     1200 coupe race suspension setup? jared 2008/5/7 3:11
       Re: 1200 coupe race suspension setup? sikyne 2008/5/7 3:53
         Re: 1200 coupe race suspension setup? sikyne 2008/5/7 4:02
         Re: 1200 coupe race suspension setup? jared 2008/5/7 4:32
           Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 4:50
             Re: 1200 coupe race suspension setup? bert 2008/5/7 6:35
               Re: 1200 coupe race suspension setup? bobthebuilder 2008/5/7 10:56
                 Re: 1200 coupe race suspension setup? sikyne 2008/5/7 23:25
                   Re: 1200 coupe race suspension setup? Rallytwit 2008/5/8 7:36
       Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 3:57
       Re: 1200 coupe race suspension setup? Rallytwit 2008/5/7 4:40
