Re: A completely different A-series build!
The A15 piston used a lower deck height than the A14 because, with the same rod as the A14, the A15 crank pushed the wrist pin higher up the bore, so a lower crown was needed to prevent the piston from poping out the top.
In an A14 it will fall short of the top of the block by about 2.5mm.
Addidionally, because the piston in an A15 displaced an additional 22cc of air in it's journey from the bottom to the top, & it was trying to squeeze it into the same size combustion chamber as the a14, it became necessary to make a deeper bowl in the piston crown to bring the compression ratio to about the same as the previous engines.
With A15 pistons you will drop the compression by a significant amount & even the squish band will be non functioning with the piston falling short by 2.5mm so this can't be good.
Even flat top A15 pistons wont save it.
The beauty of the later intake manifolds is the fact that they are water heated so make sure that this feature is fully operational even if you enlarge the holes under the ports fractionally with a drill.
You know, drivers of more powerfull cars may pass you easily on the freeway, but the smile you get when you top up the tank for pocket change while they re-mortgage the house to fill up can make it worthwhile sometimes. I know it does for me, particularly when fuel prices hit a record high recently. I was laughing all the way to the bank.
P.S. What most people never realise is that the most efficient engine is a constant speed engine as all of the parameters can be tailored to this specific operating environment for maximum benefit.
This is why large reciprocating piston aircraft engines are constant speed engines using the prop pitch like a sliding ratio trans to handle speed & load.
This is why professional 'economy drivers' try to keep their vehicle speed, & at least the engine speed, within a narrow rpm band wherever possible. Once this optimum engine speed is determined, keeping it there is an edge you can use.
Posted on: 2008/8/29 15:45
Love your Datsun.
Treat it well.
Subject Poster Date
     A completely different A-series build! blownb310 2008/8/29 3:06
       Re: A completely different A-series build! Anonymous 2008/8/29 3:10
         Re: A completely different A-series build! Dodgeman 2008/8/29 3:49
           Re: A completely different A-series build! Rallytwit 2008/8/29 3:57
             Re: A completely different A-series build! PIGDOG 2008/8/29 4:11
               Re: A completely different A-series build! 1000Coupe 2008/8/29 5:31
                 Re: A completely different A-series build! Dodgeman 2008/8/29 13:42
                   Re: A completely different A-series build! beattie 2008/8/29 14:26
                     Re: A completely different A-series build! Dodgeman 2008/8/29 14:46
                       Re: A completely different A-series build! blownb310 2008/8/29 15:18
                         Re: A completely different A-series build! Dodgeman 2008/8/29 15:45
                           Re: A completely different A-series build! blownb310 2008/8/29 16:01
                             Re: A completely different A-series build! Dodgeman 2008/8/29 16:06
                               Re: A completely different A-series build! kelmo 2008/8/29 19:33
                                 Re: A completely different A-series build! blownb310 2008/8/29 20:28
                                   Re: A completely different A-series build! blownb310 2008/8/30 13:42
                                     Re: A completely different A-series build! Anonymous 2008/8/30 14:00
                                       Re: A completely different A-series build! blownb310 2008/8/30 14:14
                                       Re: A completely different A-series build! supafatto 2008/8/30 14:15
                                         Re: A completely different A-series build! kelmo 2008/8/30 21:20
                               Re: A completely different A-series build! Fandatstick 2008/8/31 10:36
                                 Re: A completely different A-series build! Dodgeman 2008/8/31 15:32
                                   Re: A completely different A-series build! blownb310 2008/9/1 3:41
                                     Re: A completely different A-series build! 1000Coupe 2008/9/2 4:35
       Re: A completely different A-series build! ddgonzal 2008/8/29 6:23
         Re: A completely different A-series build! cheater_5 2008/8/29 7:04
         Re: A completely different A-series build! Sumith 2009/4/21 8:54
           Re: A completely different A-series build! ddgonzal 2009/4/21 17:50
           Re: A completely different A-series build! blownb310 2009/4/22 2:37
             Re: A completely different A-series build! LONGBROW 2009/4/23 4:01
               Re: A completely different A-series build! 1000Coupe 2009/4/23 4:22
             Re: A completely different A-series build! Sumith 2009/4/24 9:10
               Re: A completely different A-series build! ddgonzal 2009/4/25 6:47
                 Re: A completely different A-series build! blownb310 2009/4/30 3:30
                   Re: A completely different A-series build! ddgonzal 2009/4/30 6:35
                   Re: A completely different A-series build! B2Slow 2009/5/2 7:32
                     Re: A completely different A-series build! blownb310 2009/5/28 2:09
                   Re: A completely different A-series build! blownb310 2009/5/28 2:01
                     Re: A completely different A-series build! ddgonzal 2009/5/28 5:03
                       Re: A completely different A-series build! blownb310 2009/5/29 0:21
                         Re: A completely different A-series build! ddgonzal 2009/5/30 6:22
                           Re: A completely different A-series build! blownb310 2009/6/15 18:58
                             Re: A completely different A-series build! ddgonzal 2009/6/17 6:19
                               Re: A completely different A-series build! blownb310 2009/6/18 3:26
                                 Re: A completely different A-series build! ddgonzal 2009/6/18 4:36
                       Re: A completely different A-series build! Dodgeman 2009/7/18 18:34
       Re: A completely different A-series build! sikyne 2008/8/31 1:24
         Re: A completely different A-series build! D 2008/8/31 4:35
           Re: A completely different A-series build! dazza1200 2008/8/31 4:52
           Re: A completely different A-series build! Dodgeman 2008/8/31 5:27
             Re: A completely different A-series build! Dodgeman 2008/9/13 12:00
               Re: A completely different A-series build! blownb310 2008/9/28 4:05
                 Re: A completely different A-series build! blownb310 2008/10/4 3:17
                   Re: A completely different A-series build! Dundee1000 2008/10/4 4:30
                     Re: A completely different A-series build! Mildman 2008/10/4 4:33
                       Re: A new A-series mpg record? blownb310 2008/10/9 2:55
                         Re: A new A-series mpg record? Ianey 2008/10/9 3:59
                           Re: A new A-series mpg record? wolki101 2008/10/9 4:06
                             Re: A new A-series mpg record? LittleFireyOne 2008/10/10 1:42
                               Re: A new A-series mpg record? blownb310 2008/10/10 13:31
                                 Re: A new A-series mpg record? Dodgeman 2008/10/14 3:33
                                   Re: A new A-series mpg record? blownb310 2008/10/14 3:46
                                     Re: A new A-series mpg record? ROConnor 2008/10/14 7:30
                                       Re: A new A-series mpg record? Dodgeman 2008/10/14 9:31
                                 Re: A new A-series mpg record? Fandatstick 2008/10/16 10:27
                                   Re: A new A-series mpg record? Dodgeman 2008/10/16 10:56
                                     Re: A new A-series mpg record? ROConnor 2008/10/16 11:24
                                     Re: A new A-series mpg record? Fandatstick 2008/10/18 14:00
                                       Re: A new A-series mpg record? blownb310 2008/10/25 0:37
                                         Re: A new A-series mpg record? Rallytwit 2008/10/25 3:02
                                           Re: A new A-series mpg record? Dodgeman 2008/10/25 3:44
                                             Re: A new A-series mpg record? blownb310 2008/10/25 3:57
                                               Re: A new A-series mpg record? Dodgeman 2008/10/25 5:11
                                                 Re: A new A-series mpg record? ROConnor 2008/10/25 7:36
                                                   Re: A new A-series mpg record? blownb310 2008/10/25 14:47
                                                     Re: A new A-series mpg record? Datsunitus 2008/10/25 16:19
                                                       Re: A new A-series mpg record? blownb310 2008/10/25 16:23
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 16:25
                                                           Re: A new A-series mpg record? blownb310 2008/10/25 16:26
                                                       Re: A new A-series mpg record? Gary_P 2008/10/25 16:37
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 17:15
                                                           Re: A new A-series mpg record? Gary_P 2008/10/25 19:41
                                                     Re: A new A-series mpg record? Dodgeman 2008/10/26 1:00
                                                       Re: A new A-series mpg record? D 2008/10/26 1:50
                                                         Re: A new A-series mpg record? ROConnor 2008/10/26 6:30
                                                           Re: A new A-series mpg record? D 2008/10/27 13:58
                                                       Re: A new A-series mpg record? blownb310 2008/10/27 19:37
                                                         Re: A new A-series mpg record? femtnmax 2008/12/1 3:28
                                                           Re: A new A-series mpg record? blownb310 2008/12/1 3:47
                                                             Re: A new A-series mpg record? femtnmax 2008/12/6 3:45
                                                               Re: A new A-series mpg record? blownb310 2008/12/6 4:19
        Re: A new A-series mpg record? femtnmax 2008/12/7 2:32
        Re: A new A-series mpg record? blownb310 2008/12/7 15:00
        Re: A new A-series mpg record? femtnmax 2008/12/8 3:05
        Re: A new A-series mpg record? ddgonzal 2008/12/13 11:07
        Re: A completely different A-series build! blownb310 2009/4/20 16:13
        Re: A completely different A-series build! Gary_P 2009/4/20 17:19
        Re: A completely different A-series build! blownb310 2009/4/21 3:42
        Re: A completely different A-series build! ddgonzal 2009/4/21 5:42
                           Re: A new A-series mpg record? Fandatstick 2008/10/14 2:49
                             Re: A new A-series mpg record? blownb310 2008/10/14 3:13
       Re: A completely different A-series build! pager 2008/9/1 4:05
         Re: A completely different A-series build! D 2008/9/2 4:03
           Re: A completely different A-series build! Dodgeman 2008/9/2 10:18
             Re: A completely different A-series build! reuby_tuesday 2008/9/2 11:49
               Re: A completely different A-series build! Dundee1000 2008/9/2 12:39
                 Re: A completely different A-series build! reuby_tuesday 2008/9/2 12:56
             Re: A completely different A-series build! blownb310 2008/9/2 12:58
               Re: A completely different A-series build! dazza1200 2008/9/3 13:19
                 Re: A completely different A-series build! blownb310 2008/9/3 22:27
                   Re: A completely different A-series build! Dodgeman 2008/9/4 0:21
                     Re: A completely different A-series build! blownb310 2008/9/4 1:30
                     Re: A completely different A-series build! blownb310 2008/9/4 1:35
                       Re: A completely different A-series build! Dodgeman 2008/9/4 2:53
                         Re: A completely different A-series build! racinaround 2008/9/4 4:05
                           Re: A completely different A-series build! blownb310 2008/9/4 4:28
                             Re: A completely different A-series build! blownb310 2008/9/4 4:33
                         Re: A completely different A-series build! Gary_P 2008/9/4 4:39
                           Re: A completely different A-series build! blownb310 2008/9/11 1:58
                             Re: A completely different A-series build! Fandatstick 2008/9/13 11:35
       Re: A completely different A-series build! DaveB 2008/9/2 5:12
         Re: A completely different A-series build! pager 2008/9/2 6:28
       Re: A completely different A-series build! LONGBROW 2009/4/24 1:54
       Re: A completely different A-series build! blownb310 2009/7/18 3:16
       Re: A completely different A-series build! blownb310 2009/7/20 13:08
       Re: A completely different A-series build! superbin 2009/7/20 14:48
         Re: A completely different A-series build! ddgonzal 2009/7/20 18:08
       Re: A completely different A-series build! billybuilt 2009/7/20 21:07
         Re: A completely different A-series build! ddgonzal 2009/7/21 0:51
         Re: A completely different A-series build! D 2009/7/21 0:57
       Re: A completely different A-series build! jmac 2009/7/21 10:52
         Re: A completely different A-series build! D 2009/7/21 11:10
           Re: A completely different A-series build! Dodgeman 2009/7/21 16:42
             Re: A completely different A-series build! ddgonzal 2009/7/21 17:18
           Re: A completely different A-series build! D 2009/7/23 2:41
             Re: A completely different A-series build! ddgonzal 2009/7/23 4:17
               Re: A completely different A-series build! D 2009/7/23 5:06
               Re: A completely different A-series build! blownb310 2009/7/29 3:53
       Re: A completely different A-series build! superbin 2009/7/23 7:40
       Re: A completely different A-series build! benny 2009/7/23 7:50
       Re: A completely different A-series build! blownb310 2009/7/29 3:48
         Re: A completely different A-series build! Dodgeman 2009/7/29 17:34
           Re: A completely different A-series build! blownb310 2009/7/30 2:34
           Re: A completely different A-series build! D 2009/7/30 2:36
             Re: A completely different A-series build! 1000Coupe 2009/7/30 3:53
       Re: A completely different A-series build! jmac 2009/7/29 4:35
       Re: A completely different A-series build! blownb310 2009/8/2 20:19
         Re: A completely different A-series build! ddgonzal 2009/8/3 0:54
           Re: A completely different A-series build! blownb310 2009/8/3 3:02
             Re: A completely different A-series build! Dodgeman 2009/8/5 15:53
       Re: A completely different A-series build! ang94541 2009/8/6 1:35
         Re: A completely different A-series build! blownb310 2009/8/10 18:49
       Re: A completely different A-series build! D 2009/8/6 5:09
         Re: A completely different A-series build! blownb310 2009/8/10 18:51
           Re: A completely different A-series build! ddgonzal 2009/8/12 7:01
             Re: A completely different A-series build! blownb310 2009/8/14 19:29
       Re: A completely different A-series build! superbin 2009/8/14 19:45
         Re: A completely different A-series build! D 2009/8/15 0:13
       Re: A completely different A-series build! blownb310 2009/8/15 4:44
       Re: A completely different A-series build! blownb310 2009/8/15 4:50
       Re: A completely different A-series build! blownb310 2009/8/16 2:19
       Re: A completely different A-series build! blownb310 2009/8/18 2:49
       Re: A completely different A-series build! 1000Coupe 2009/8/18 3:03
         Re: A completely different A-series build! D 2009/8/18 6:08
           Re: A completely different A-series build! blownb310 2009/8/21 17:59
             Re: A completely different A-series build! ang94541 2009/8/25 5:37
               Another new record! blownb310 2009/8/28 0:30
                 Re: A completely different A-series build! D 2009/8/28 0:59
                   Re: A completely different A-series build! ddgonzal 2009/8/28 6:54
                     Re: A completely different A-series build! blownb310 2009/8/28 15:55
                       Re: A completely different A-series build! D 2009/8/29 2:26
                       Re: A completely different A-series build! ddgonzal 2009/8/29 5:57
                         Re: A completely different A-series build! Rallytwit 2009/8/29 6:24
                           Re: A completely different A-series build! ROConnor 2009/8/29 6:28
                             Re: A completely different A-series build! blownb310 2009/9/5 21:56
                       Re: A completely different A-series build! Dodgeman 2009/8/31 14:53
                         Re: A completely different A-series build! blownb310 2009/9/5 22:01
                           Re: A completely different A-series build! Fandatstick 2009/9/6 10:31
                             Re: A completely different A-series build! blownb310 2009/9/6 21:29
                               Re: A completely different A-series build! Dodgeman 2009/10/19 6:56
                       Re: A completely different A-series build! ang94541 2009/9/1 4:42
       Re: A completely different A-series build! superbin 2009/8/28 7:24
       Re: A completely different A-series build! 1000Coupe 2009/10/20 2:56
         Re: A completely different A-series build! ddgonzal 2009/10/20 3:47
           Re: A completely different A-series build! 1000Coupe 2009/10/20 4:58
           Re: A completely different A-series build! Dodgeman 2009/10/21 17:40
       Re: A completely different A-series build! lamb_daiquiri 2011/6/4 0:59
       Re: A completely different A-series build! blownb310 2011/6/5 3:22
       Re: A completely different A-series build! ddgonzal 2011/6/5 3:56
