Re: Car uses coolant but not water?
From Adelaide, Australia
Are you filling to top of radiator, your meant to leave 20mm or so for expansion.
Use a recovery bottle and correct radiator cap with plastic valve and you won't loose coolant.
Posted on: 2008/11/18 7:15
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Subject Poster Date
     Car uses coolant but not water? candyflippa 2008/11/18 6:44
       Re: Car uses coolant but not water? candyflippa 2008/11/18 6:51
         Re: Car uses coolant but not water? PIGDOG 2008/11/18 7:02
         Re: Car uses coolant but not water? DatJaffa 2008/11/18 7:04
           Re: Car uses coolant but not water? candyflippa 2008/11/18 7:05
             Re: Car uses coolant but not water? DatJaffa 2008/11/18 7:11
               Re: Car uses coolant but not water? WhiteSedan 2008/11/18 7:15
                 Re: Car uses coolant but not water? DatJaffa 2008/11/18 7:22
                   Re: Car uses coolant but not water? candyflippa 2008/11/18 8:03
                     Re: Car uses coolant but not water? candyflippa 2008/11/18 8:05
                       Re: Car uses coolant but not water? WhiteSedan 2008/11/18 8:05
                         Re: Car uses coolant but not water? candyflippa 2008/11/18 8:10
                         Re: Car uses coolant but not water? DatJaffa 2008/11/18 8:37
                           Re: Car uses coolant but not water? WhiteSedan 2008/11/18 8:47
                             Re: Car uses coolant but not water? DatJaffa 2008/11/18 9:02
                               Re: Car uses coolant but not water? revhead001 2008/11/18 9:06
                               Re: Car uses coolant but not water? WhiteSedan 2008/11/18 9:14
                                 Re: Car uses coolant but not water? DatJaffa 2008/11/18 9:26
                                   Re: Car uses coolant but not water? DatJaffa 2008/11/18 9:29
                                     Re: Car uses coolant but not water? WhiteSedan 2008/11/18 9:33
                                       Re: Car uses coolant but not water? candyflippa 2008/11/18 9:38
                                         Re: Car uses coolant but not water? ROConnor 2008/11/18 9:59
                                           Re: Car uses coolant but not water? Lobster 2008/11/18 13:55
                                             Re: Car uses coolant but not water? bert 2008/11/18 22:01
                                               Re: Car uses coolant but not water? DatJaffa 2008/11/19 0:27
                                                 Re: Car uses coolant but not water? Anonymous 2008/11/19 0:32
                                                   Re: Car uses coolant but not water? DatJaffa 2008/11/19 0:34
                                                     Re: Car uses coolant but not water? minitruckin 2008/11/19 2:05
                                   Re: Car uses coolant but not water? Pantelkiko 2008/11/18 9:32
