need help! 1200 ute diff conversion
Not too shy to talk
From Drouin, Vic
hey guys, need some help on my ute diff conversion to my 1974 120y hatch. the uni join on the ute diff is larger than that of my 120y tailshaft, so, does a 1200 ute tailshaft fit straight in? same length and would it fit into the gearbox? i might be able to get a tailshaft. or would it be better to get one made up? expensive??
cheers
Posted on: 2009/1/27 9:12
Re: need help! 1200 ute diff conversion
From Melbourne, Australia
i doubt the ute shaft will be correct length (you could check by comparing the wheelbase of the 120y vs. the 1200
it would fit into your gearbox
getting a shaft custom made with new unis and using the flanges you provide should be between 200-250
Posted on: 2009/1/27 9:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From bathurst nsw
hi pete, good news is that they are the same gearbox so if you got a ute tailshaft you would be set yoke wise. bad news is i dont know if they will fit straight in length wise. when i had my race tailshaft made it was $160 so not overly dear to get the job done first time.
hope that helps cheers kurt
Posted on: 2009/1/27 9:19
My car gets me from A to B...Just faster ;)
From Adelaide, Australia
It will fit as long as the 120y is manual. If you can't get the ute one, then you'll need to get another shortened, a sunny one would be a good one to shorten as will have the correct ends.
Posted on: 2009/1/27 9:22
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Not too shy to talk
From Drouin, Vic
thanks for the quick response. what would guys like me do without guys like you that know what they're doing?? hopefully this one wont die like my last one hehe.
cheers
Posted on: 2009/1/27 9:26
From perth mandurah
i think my ute has a shortened tailshaft in it because it has a weld in it, and it looks the same as one that was in another thread and it also shows a standard tail shaft
Posted on: 2009/2/16 6:28
