how hot is too hot?
From northern 'burbs adelaide
just wondering what the safe operating temps of an A14 are in degrees
Posted on: 2009/1/28 4:32
Re: how hot is too hot?
Posted on: 2009/1/28 4:38
but how hot is the H mark?
Posted on: 2009/1/28 4:43
From newcastle, NSW
mine runs at about 185F, i have an autometer gauge, goes up a fraction when its stinking hot.
Posted on: 2009/1/28 4:45
yea mine normally runs about 80C but today (45C outside) it got up to 107C and then i turned the car off
Posted on: 2009/1/28 4:48
Just below 100C should be OK. If you have a 14psi radiator cap it can run hotter without damage.
The gauges are not calibrated, and vary as to what the H mark is.
Posted on: 2009/1/28 5:02
well i'm running a mechanical aftermarket gauge so i dunno where the H mark is
Posted on: 2009/1/28 7:27
From Brisvegas, oz
in hot weather up here mine in traffic (kfc drivethru) will sometimes reach about 105 C which is very close to the inner hot mark. i have found that some of the older guages are way off
Posted on: 2009/1/28 9:02
www.camerasplus.com.au
mine reads just above half when at opperating temp on the stock gauge and 175 f on the mechanical gauge. when it gets to 190 f it is just below H. I tend to get scared when it gets to almost 200 f as who knows how accurate the gauge is bit also the car tends to run no hotter than 185 any other time.
so at 205 f its over H on the new gauge.
pic with old mechanical gauge
Posted on: 2009/1/28 10:38
on that gauge my car would read bout 225F
Posted on: 2009/1/28 10:52
