Re: HELP!!!!!!! 1200 a12 wont start
not sure if this will help but have u checked the fusible link at the battery?
Posted on: 2009/5/17 3:57
finally gettin the ca18 ute project underway
Sunny’s were made to be drifted, it says so in the factory service manual: Service after every drift day and mountain tounge or 100,000km’s
Quite a regular
is one of these the fusible link?????
Posted on: 2009/5/17 4:35
From Bathurst - NSW
Do a search in the wiki, there is a photo of it somewhere. It comes directly from the battery.
Posted on: 2009/5/17 5:36
Quite a regular
it seams that it has been taken out and it is straight through
Posted on: 2009/5/17 5:57
Quite a regular
Posted on: 2009/5/17 6:04
Your battery cables are corroded! That's the number "no start" cause. Take them off, clean them, coat lightly with grease, then put back together.
Take off all those wires too, sand/scrape the connectors to "shiny" condition and put back together. The two twisted wires might be corroded too.
If you get an electrical problem later on, with no fusible link you risk melting the whole wiring harness. Go to the wreckers and get a $1 fusible link to put back in there. Repco sells them too. I used one from a Ford.
Posted on: 2009/5/17 6:10
Quite a regular
i have power to the coil and to the balister but i have no spark
Posted on: 2009/5/17 6:13
Quite a regular
thanks - I will clean all terminal and put in place a ford fusable link. As discussed before, I have power to the ballast resistor, the coil however, there seems not to spark at the plugs, the distributor is still in place and locked down as it was when it was running, maybe - i need to look at replacing the condensor once again - it was new only month ago - I did try and start it with old condensor from my ford however, this made little difference, there cheap so I might just grab a new one and see what happens - thanks - shall keep every on posted - fingers crossed so to speak
Posted on: 2009/5/17 6:23
Get a FL for Datsun 1200, if they have it. I used Ford only because I had a spare one in the garage.
Posted on: 2009/5/17 6:46
Quite a regular
i dont no what i ment to get for the fusable link went to auto one and they said then need to see the old one i dont have one???
Posted on: 2009/5/17 7:46
« 1 (2) 3 »
