Re: 1200 Sedan VIC (Registered, Auto Tunnel)
From Melbourne AUS
in that case you'll need a 5mm approx spacer to clear the front strut. you can run them without a spacer on the rear of a sedan but
again a 5mm spacer in the rear will stop the tyres from scrubbing the inner guards on hard cornering or uneven surfaces.
Posted on: 2009/9/28 12:23
1973 B110 A12
Not too shy to talk
From wagga
Ok m8 thanks for the info appriciate it, i might stick with trx for the time being till i work things out.
Cheers Marty
Posted on: 2009/9/29 12:34
trx still rub on rear under hard cornering
Posted on: 2009/9/29 12:43
Car free
« 1 (2)
