Re: 13x7 mini lites and guards
Frodaddy
Why are you running such skinny tyres on your 7" rims. According to the "Tyre & Rim Association of Australia" the P175 tyre width is permitted on a 7" rim in 60 profile sizes & below. You are running an ILLEGAL combination. Ever wonder why some things are ILLEGAL? I wonder if it is because it is UNSAFE.
I had always thought that the purpose of wide rims was to allow wide tyres, yet the P175 tyre is both legal & safe on a rim right down to 4-1/2".
I run 185 x 60 x 13" on the front with 5-1/2" rims. This tyre is 552mm in diameter which is the same size as the original [stock] tyre. This means no scrubbing on the inner guard when turning.
Your tyre is nominally 584mm in diameter & i suspect that it rubs sometimes.
I also run 205 x 60 x 13" on the rear on the same 5-1/2" rims. It seems to me that you could have a better tyre selection available to you if you used smaller rims instead of needing pizza cutters to clear the guards.
Motto Think twice, act once.
Chris
P.S.
The 185 x 60 x 14 is nominally 578mm in diameter & i wonder if they rub the inner guard too. This tyre was DESIGNED around a 5" rim, as was your tyre.
Posted on: 2003/10/12 11:56
Subject Poster Date
     13x7 mini lites and guards datman 2003/10/10 10:50
       Re: 13x7 mini lites and guards Frodaddy 2003/10/11 5:36
         Re: 13x7 mini lites and guards Frodaddy 2003/10/12 10:47
           Re: 13x7 mini lites and guards Dodgeman 2003/10/12 11:32
         Re: 13x7 mini lites and guards Dodgeman 2003/10/12 11:56
           Re: 13x7 mini lites and guards L18_B110 2003/10/12 23:28
             Re: 13x7 mini lites and guards Frodaddy 2003/10/16 7:42
               Re: 13x7 mini lites and guards datman 2003/10/16 8:18
                 Re: 13x7 mini lites and guards B110SSS 2003/10/16 8:48
                   Re: 13x7 mini lites and guards Dodgeman 2003/10/16 14:59
                     Re: 13x7 mini lites and guards B110SSS 2003/10/17 0:42
                       Re: 13x7 mini lites and guards Frodaddy 2003/10/18 3:38
                         Re: 13x7 mini lites and guards B110SSS 2003/10/18 6:32
                           Re: 13x7 mini lites and guards luv_my_68_wagon_1000 2003/10/19 7:54
                             Re: 13x7 mini lites and guards Quinn 2003/10/19 11:03
                               Re: 13x7 mini lites and guards Dodgeman 2003/10/19 11:28
                               Re: 13x7 mini lites and guards Quinn 2003/10/19 11:47
                                 Re: 13x7 mini lites and guards 2332owner 2003/10/19 12:25
