Re: a12 no power at low revs
The best place to start is with a full standard tuneup. You know, check the plugs, points, timing & have a listen to the tappets. If they are a bit quiet, then run the feeler gauge through them too.
Spray some of the good stuff through the carb & if it has a bad flat spot, then swap the plug leads on cylinders 2 & 3 then start it up. A few nasty backfires should dislodge any rubbish in the main jets, but do it with the air cleaner in place for best results & greatest safety.
If the carb is the problem & the backfires clear it, then drop the two brass plugs from the bottom of the fuel bowl & with any luck the dislodged particle will be washed out when the bowl drains as these plugs are at the base of a well at the bottom of the bowl.
Make sure that you refit the plug leads correctly & that all the drained fuel has dried.
Oops, just noticed, it's a non standard carb.
Posted on: 2010/2/1 10:21
Love your Datsun.
Treat it well.
Subject Poster Date
     a12 no power at low revs datto_mog 2010/1/31 8:52
       Re: a12 no power at low revs BRUTE 2010/1/31 9:12
       Re: a12 no power at low revs levey 2010/1/31 9:35
         Re: a12 no power at low revs datto_mog 2010/1/31 10:18
       Re: a12 no power at low revs Anonymous 2010/1/31 10:59
         Re: a12 no power at low revs ddgonzal 2010/1/31 17:25
           Re: a12 no power at low revs Dodgeman 2010/2/1 10:21
       Re: a12 no power at low revs A14force 2010/2/2 5:28
       Re: a12 no power at low revs datto_mog 2010/2/5 9:10
       Re: a12 no power at low revs levey 2010/2/5 12:09
       Re: a12 no power at low revs Dodgeman 2010/2/7 11:30
