A15 crank > A14 block
Quite a regular
From Perth
will a A15 crank fit in a A14 block? Pros & Cons?
Posted on: 2010/6/2 2:21
Re: A15 crank > A14 block
why bother? They are basically the same except the casting changes for the larger crank throws.
Just use the A15 block. There are no PROs to using an A14 block with A15 crank.
Posted on: 2010/6/2 2:37
Quite a regular
From Perth
cause i have those parts
Posted on: 2010/6/2 2:39
From sydney.nsw
yes they fit ,only the pistons are different in comp height.and sump is sightly different because of stroke.cheers
Posted on: 2010/6/2 8:56
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Perth
My engine is a 14 block with 15 crank
Yes they do go together
The 14 and 15 rod are the same... as bige says... just change to the appropriate 15 piston to get the crown height right
And make sure the rods don't touch the side of the sump ... mine didn't need clearancing... but as mentioned... some do
Posted on: 2010/6/2 11:27
