Re: How to wire up an electronic fuel pump
Yep, shouldn't matter. Hilux just copied Datsun Truck
Posted on: 2010/6/16 7:20
From ACT
Lol, those devious japanese engineers, As soon as I saw this engine (18RGEU) I though damm! Toyota copied the FJ20?!
Posted on: 2010/6/16 7:23
Now riding dirtbikes:
Lots of A series Datto stuff for sale
From Castro Valley,CA USA
electric fuel pump circuit
Here is how I did mine. Sorry about the quality of the drawing.
The oil pressure switch is a SPDT(single pole, double throw). The common is grounded. With no oil pressure the dash light turns on. With oil pressure and the dash switch in the on position, the relay/fuel pump turns on.
Also, with no oil pressure(engine off) and the dash switch in the on position, I can press the override button to momentarily turn on the pump.
Note that this is probably only suited for carbed engines since the relay/pump won't turn on for a few seconds after the engine has started.
I'm not trying to confuse anyone. Just showing a slightly different variation.
Posted on: 2010/6/16 7:54
From ACT
Thanks ang94541
So you got the fuel pump set to go after the oil pressure switch is thrown, but u can still prime the fuel system with the override button before cranking yeah??
Posted on: 2010/6/16 7:59
that's a good idea.
Posted on: 2010/6/16 8:53
From ACT
yah thats what I thought DD
Very clever indeed, a great use of the available wiring!!
thanks again ang94541!!!
So anyway it runs, WOOT!!!!
Had the ballast resistor cable on neg coil not +ve
What a douche!!!!
Its backfiring a bit out the carbs and zorst but she bangs man she bangs!!!
Now to get a zorst made up and job done!!!!
Posted on: 2010/6/16 9:04
« 1 2 (3)
