« 1 2 3 (4) 5 6 7 »
#31 Re: fitting trx rear brakes on 1000 front end. can this work?
TUF-110 Posted on: 2010/8/3 3:44
Im getting stuck into this atm as im sick of drums, my setup consist of r31 rear disks and caliper brackets and vs commodore rear calipers
#32 Re: fitting trx rear brakes on 1000 front end. can this work?
D Posted on: 2010/8/3 4:50
When I asked the same thing about 8 years ago to Mammie motors
who are datsun 1000 specialists, they raced and owned about 40
of the things, they said that its more work with that bracket
than the sigma one. Any1 is open to prove them wrong.
#33 Re: fitting trx rear brakes on 1000 front end. can this work?
TUF-110 Posted on: 2010/8/3 5:47
Well picked up all the bits today vs caliper and r31 rear disk fit nicely under a 13" not just to make up the bracket and plumb it in! progress ahoy!
#34 Re: fitting trx rear brakes on 1000 front end. can this work?
dattoman_1000 Posted on: 2010/8/3 11:06
Small pad though
But anything an improvement
#35 Re: fitting trx rear brakes on 1000 front end. can this work?
TUF-110 Posted on: 2010/8/3 11:40
Bracket modified everything bolted up now to plumb it all in!
#36 Re: fitting trx rear brakes on 1000 front end. can this work?
matty Posted on: 2010/8/3 12:25
Any chance of some photos mate?
#37 Re: fitting trx rear brakes on 1000 front end. can this work?
D Posted on: 2010/8/3 13:52
POB!
Anything that does away with trying to find a set
of 1200 coupe hubs is going in the right direction
#38 Re: fitting trx rear brakes on 1000 front end. can this work?
TUF-110 Posted on: 2010/8/4 11:48
The modified bracket (ground a fair bit off to clear the lca after photo was taken) 1 hole bolts up and the other three were re-drilled
About 10 mm or slightly less clearance on the inside of my 13x6 jellybeans,
#39 Re: fitting trx rear brakes on 1000 front end. can this work?
matty Posted on: 2010/8/4 12:00
Thanks very much mate!
#40 Re: fitting trx rear brakes on 1000 front end. can this work?
TUF-110 Posted on: 2010/8/4 12:03
no worries matty :)
« 1 2 3 (4) 5 6 7 »
