1975 VB210 station wagon, Japanese import. A15 motor + spares
Quite a regular
Bought this as a minor project to daily 4-5 months ago. Now it needs to go.
I have pages of background information I can forward. Plus folders full of relevent Datsun-manuals + 3 CD's with further info.
1975 VB210 4-door station wagon, Japanese import. 223,000.
1984 Vanette A15 motor, rebuilt in 2003. Has done approx 100,000km.
Bottom end is standard using ACL parts and where possible genuine Nissan seals and gaskets. 8.5:1 comp, was suited for SC12 but was never fitted.
Block was lightly honed, not bored oversize. Original spec ACL rings fitted to dished Nissan pistons.
A12 flywheel (lighter)
Rear main started to leak, not very much. Probably 200mL every few months.
A15 Sunny coupe oval-port head (factory twin-carbs). Short turns have been ported, oversize (1.75") stainless valves, seats, inserts, solid lifters.
Wet manifold water jackets have been dowelled.
Currently fitted with re-jetted Sunny A15 carburettor, but was previously running auto choke Vanette A15 carb with A12 jets (also supplied). Factory Vanette filter box and piping.
Vanette non-electric distributor, new points, condensor, resistor.
Larger voltage regulator to suit charging larger battery.
Starter relay added.
Low beam and high beam relay switched and independently fused
Extractors, 2" full-length exhaust. Fairly quiet.
Sunny wagon 60 series 4-speed manual, Xtreme H/D clutch. Original Hitachi H150 diff.
Gas inserts in front struts.
Reset leaf springs, Monroe GT Gas 1200 ute rear shocks.
New front wheel bearings, ball joints, tie rod ends, Nolothane sway bar link bushes and Radius rod bushes.
Original 12x4 steel with near new 155/80. Also have a set of 13x5 B310 steels with average 175/70.
Mostly original Antarctic white paint. Getting a little thin + has a few older touch-ups. Still quite presentable
LHS front guard has been replaced at some stage, shows signs of a minor repair to RHS rear corner (near taillight).
Minor rust bubbles in two doors, LHS front guard and bonnet.
Interior is mostly original black vinyl. Cigarette burn in rear seat, dash is cracked. Has Bluebird front seats.
1200 Coupe tachometer, original AM radio.
Asking price is $1700
with all spares (grilles, front bumper, lights, badges, wagon bits, suspension upgrades, lowered springs, spare struts for coilovers etc)
Located Modbury.
Thanks, Ben.
Posted on: 2011/2/10 10:27
Edited by benzo on 2011/2/11 10:50:40
Edited by benzo on 2011/2/15 9:34:48
Re: 1975 VB210 station wagon, Japanese import. A15 motor + spares
From Sydney NSW
Would like to see some pics, sounds sweet
Posted on: 2011/2/10 14:13
Quite a regular
New info + a quick photo.
Will get better pics over weekend. Seem's to drive good ATM.
Posted on: 2011/2/11 10:51
From Wagga Wagga, NSW
Nooooo benny this thing is mint! someone buy this so benny can build more cool #OOPS# :)
Posted on: 2011/2/12 3:15
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Quite a regular
Thanks Jake!
I need to finish my Corolla, this needs to go.
Posted on: 2011/2/13 6:27
Quite a regular
Price drop
I need to re-fit Vanette Carb ATM.
Posted on: 2011/2/15 9:33
Quite a regular
bump
Haven't had time to swap carb yet.
Posted on: 2011/2/20 5:14
Edited by benzo on 2011/2/22 8:14:27
Quite a regular
Now has Vanette carb re-fitted and running like a champ!
$1700, two months reg!
Posted on: 2011/2/22 8:15
Not too shy to talk
From Westbury Tasmania
where is modbury ??
Posted on: 2011/2/22 8:44
Adelaide SoUF OStrayia
Posted on: 2011/2/22 8:47
