A15 valve clearance
From Kabankalan City,Philippines
hi there,
do any of you guys have specs for valve clearance on an A15 engine? Im trying to tune up my A15, problem is I dont know whats the correct clearances for the exhaust and intake valves,when its hot and cold...thanks....
Posted on: 2004/2/10 2:36
Re: A15 valve clearance
From Christchurch. NZ
A12, Hot intake and exhaust 0.35mm (0.014in) I presume the A15 should be the same
Posted on: 2004/2/10 7:15
A15 might have a different spec (though I doubt it). In any case with a stock cam, the A14 specs can be used safely. See the tune up article.
Posted on: 2004/2/10 7:27
From Tas
I have an A15 Engine Manual and will confirm that they are:
0.35mm or (0.014") both inlet and exhaust
when hot
Also just in case anyone wants to know
Inlet valve sizes compared to A12:
A15 Inlet - 37.0mm
A12 Inlet - 35.0mm
A15 Exhaust - 30.00mm
A12 Exhaust - 29.00mm
Your Welcome....................
Posted on: 2004/2/10 8:14
