#11 Re: engines for dattos
whoridas_girl Posted on: 2011/8/13 14:26
if i could FIND a sr20ve ..... the only engine we could both AGREE on but trying to find one is another thing!!!
EDIT: one that is set up for rwd anyway!!!
#12 Re: engines for dattos
bige Posted on: 2011/8/13 14:28
what do mean SHOULD your car your call, im sure he will see it your way. lol
#13 Re: engines for dattos
whoridas_girl Posted on: 2011/8/13 14:28
hahahahahahahahaha
#14 Re: engines for dattos
wards Posted on: 2011/8/13 16:04
why not throw the all alloy cg13de from the nissan k11 micra into the arguement, its twin cam, lighter than most other options, nissan related ,physicaly not too big, and no engineer needed as not too big jump in capacity in standard form. It's FWD but not that hard to convert to RWD, and with a bit of work i have got one out to 1680cc.
jpg  rack cross &engine.jpg (124.35 KB)
9512_4e46928e1d280.jpg 600X800 px
#15 Re: engines for dattos
kululadotgroen Posted on: 2011/8/13 16:50
Where I live we can pretty much fit any engine and still get it registered. Obviously you have restrictions, but I was wondering you'd probably be able to fit either a QG16DE or GA16DE(if you would like to keep the block iron), and still get it legal.
A friend of mine has an Almera with the GA16DE motor, which he fitted with a turbo, I built the manifold for him. Anyway, motor was completely standard and not even the CR was dropped. He pumped around 0.8bar into it, running extra injector and methanol injection for higher than 0.4) and was making 163kw and 256nm with it. It was totally reliable and the only thing that kept on giving up the fight was the gearbox.
I was looking at it and thought that if I ever had to build another Datsun, that was what would go into it. Nothing else.
#16 Re: engines for dattos
ddgonzal Posted on: 2011/8/13 21:15
Use the Serena GA16DE gearbox, it will hold up to the turbo as it is a 71-series transmission.
#17 Re: engines for dattos
Datrotor Posted on: 2011/8/21 11:20
13b turbo :)
#18 Re: engines for dattos
whoridas_girl Posted on: 2011/8/21 11:57
Datrotor........y would i put a rotisserie in my beloved 1200???? i would die b4 i put my baby through that pain!!!
no offense intended!!
#19 Re: engines for dattos
revhead001 Posted on: 2011/8/21 12:05
Personally I like the CR14DE from the K12 Micra. Less manifolds and hardware it weighs in at 60kg. Puts out 73kw and has VVT. I'm personally in the dilemma of this engine and the CG13DE from the K11. Both all alloy and light but at least you can get aftermarket came from Tomei for the CG13DE. A little less effort to go through when someone else has done all the hard work for you.
#20 Re: engines for dattos
Posted on: 2011/8/21 12:40
Saw an add for new micro don, it's got a flip cushion on passenger seat for your handbag too
I like Honda f20c still way expensive though. Sr20de autech comes close too.
« 1 (2) 3 4 5 6 »
