Bw68 swap into 1200 sedan- any one done it?
Just wondering if anyone's done this, cause the saddles that mount to leaves are different to h150 I think (larger locating hole and bolt).
Does that sound right?
Wouldn't want to locate it on the smaller saddle to have it move round on me.
Posted on: 2012/1/2 8:24
Re: Bw68 swap into 1200 sedan- any one done it?
1200 sedan doesn't use the H150
Australian-assembled 1200 sedans use the Borg Warner 60. I don't know if anyone has swapped that for the BW68.
Pics of the BW60 are needed.
Here is the BW68
compared to Hitachi:
Posted on: 2012/1/2 8:34
I bought a locked BW68 off a member in sydney. He had welded in a plate with the correct size locator holes. Tail shaft needs to be shortened a bit too.
Posted on: 2012/1/2 8:44
Yeah I know 1200 didn't come with h150 but i swapped my h145 for h150 years ago.
I knew tail shaf needs shortenIng, I'm have to use auto one so input flange goes into l series gearbox lol.
Just those rubber mounted plates on springs with the locating holes is my query.
I have a set and ubolts etc, but supafatto couldn't unbolt the locating bolt from the leaves.
Posted on: 2012/1/2 8:48
If u zoom in on bw68 you can see the large off center holes in the pic dd posted, I'm With camo just fit a new plate on the bottom of stock ones and make the holes in the right place! Easy with that mig u have!!
I could get them off with some more time and an oxy
Posted on: 2012/1/2 9:30
Car free
Oxy- nup would cut the bolt out and replace it more likely. It really should come out
Posted on: 2012/1/2 9:41
Yeah a good clamp to hold top of bolt and some ky will fix it mik bring some with ya
Posted on: 2012/1/2 9:54
Car free
To use on you and the bolt! Lucky days!
Posted on: 2012/1/2 11:03
From Armidale N.S.W
Honestly buddy your bein to anal it wont move once you've done all 4 bolts up on each side i never had a problem with hankys bw68 and L series and i gave it some hell occasionally. just make sure you do up the 4 bolts each side evenly dont tighten them all the way one at a time.
Posted on: 2012/1/2 12:13
73 1200 wagon SOLD
Yeah I learnt that the hard ay in coupe with h145....only had2u bolts when I got it lol.......
I'm being anal yeh.... I figure it wouldn't move but to be sure.
Now onto the engine knock issue lol
Posted on: 2012/1/2 12:19
