Re: Work Equip wheels
For 205 tyres, 5.5 to 8.5 is recommended for some brands. You should go by the manufacturer's recommendation. Compare to Advan Specs
the wheels sit too far out the front gaurds with a 10mm spacer
So why not remove the spacer? Or will the tyre hit the spring? 205s are a bit wide for the front.
205 tyre will not fit on the front without rolling/pulling the guard. And since you have Stanza struts you have slightly less room. In the photo above, the front tyres are sticking out.
Extreme negative camber can also help with front guard clearance.
Posted on: 2012/2/8 2:28
Subject Poster Date
     Work Equip wheels loosekid 2012/2/7 9:24
       Re: Work Equip wheels supafatto 2012/2/7 10:05
       Re: Work Equip wheels ddgonzal 2012/2/7 18:03
         Re: Work Equip wheels loosekid 2012/2/7 22:24
       Re: Work Equip wheels DA75EZ 2012/2/7 20:37
         Re: Work Equip wheels loosekid 2012/2/8 0:18
           Re: Work Equip wheels ddgonzal 2012/2/8 2:28
             Re: Work Equip wheels loosekid 2012/2/8 10:45
               Re: Work Equip wheels lightload 2012/2/8 11:13
               Re: Work Equip wheels lightload 2012/2/8 11:16
                 Re: Work Equip wheels 1200rallycar 2012/2/8 11:38
       Re: Work Equip wheels loosekid 2012/2/7 22:50
       Re: Work Equip wheels DA75EZ 2012/2/8 20:32
