ca18det build
From Goulburn NSW
Hi guys im in the process off getting a ca18det built,just wondering can anyone tell what needs to be done to achieve 300hp also what size turbo should i put on it,was thinking 2871r.Need help so i can express what i want done to the builder,all i have said to him is build me a 300hp engine with scope for more hp if i want it.
Posted on: 2012/3/22 6:39
Re: ca18det build
A good motor builder should be telling u what he should do! You can get kits from us full forged stuff for 1500 or so! And a gt2871r will be good for 300-350 next step is 2876 but a little more lag but depends again on manifold and flow, a manifold like 6boost will make spool faster ect!
Posted on: 2012/3/22 7:04
Car free
Re: ca18det build
From Brisbane
mcdat, just get Nissan CA18DET Rebuild Kit from spoolimports.com + main and head arp bolts. Drop in pon tomei cams with race valve springs. Dream ca18det would be lewisengines 2.3l stroker kit :)) Turbo options would be 2871 with .63 rear or if you have the money 3071 .63 t3 twin scroll + 6 boost manifold
Posted on: 2012/3/22 8:16
Re: ca18det build
From Goulburn NSW
Hi guys whats the standard bore size off the ca18det.Ok its 83mm if i go 84 mm how many thou is that over.
Posted on: 2012/3/22 10:45
Edited by mcdat on 2012/3/22 11:05:26
Re: ca18det build
From Brisbane
40thou over, would only go 20thou .5 over just in case you need to hone bore later.
Posted on: 2012/3/22 11:20
Re: ca18det build
From brisbane
Are you chasing 300hp at the wheels or flywheel?
What will the car predominantly be used for?
What sort of compromises in power delivery can you live with?
What's your budget?
Posted on: 2012/3/22 21:31
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: ca18det build
From Goulburn NSW
Hi guys sorry for my ignorence but are the spool rebuild kits good quality also arp main and head bolts.Will they give me a tough engine and also when a motor is balanced what items are balanced and how do they do it.Do they need to do brand new pistons etc,i thought that they would come balanced from the factory.
Posted on: 2012/3/24 6:09
Re: ca18det build
From Campelltown,Sydney,NSW
Not being rude mate but the person building your motor should know most of this and if not why are u letting me do it mate?
Posted on: 2012/3/24 6:28
Re: ca18det build
From Goulburn NSW
Bevo he is taking care off me,he said just to trust him,that he will build me a tough motor,im asking these ?'s because i wondering whether or not i can save a bit off money here and there.He said that my ca will be fully balanced,crank prepped,honed,chunky cams big turbo and fully forged for around the 5k mark,which ive got him to committ to in the price off doing the full conversion(tubbes,fit diff, move leaf springs,build motor, electrical,fitt gauges etc etc) 25k.Basically get it on the road.
Posted on: 2012/3/24 6:42
Re: ca18det build
From brisbane
What's your budget?
Have you thought about these questions? Have you discussed them with your engine builder?
Regardless of how good he is at building motors these are things you should discuss before any work commences. For example you could potentially end up with a motor set up for drag racing when you want to compete in lap sprints.
There are plenty of us on here who have been through this with CA18DETs and there is a lot more to it than simply throwing a set of forged pistons and a rebuild kit at it.
Posted on: 2012/3/24 23:24
