WTK prices for engine swap for c18det or sr20's
From sydney,NSW
hey guys, i just got my datsun 1200 sedan and was wondering how much ppl have spent on there engine swap for the above engines, dont have to write a list, just want to kno prices that you guys hav spent... just so i can figure out if i should change the engine or keep original in it and restore it.
thankyou
Posted on: 2012/5/6 8:18
Re: WTK prices for engine swap for c18det or sr20's
From Ormeau goldcosst qld
Probs over 10k mate
Posted on: 2012/5/6 8:49
1980 datsun 1200 ute ca18det gt28 200hp
1/4 mile 13.357 at 104.52mph
From Melbourne, Australia
roughly, doing wiring and fab yourself
motor - 1000
gearbox - 350
tailshaft - 350
diff upgrade - 500
strut upgrade - 1000
turbo - 150
turbo lines - 150
silicone hose and clamps - 250
intercooler - 200
air filter - 100
loom - 100
ecu - 100
fuel pumps - 300
surge tank - 100
fuel lines and hose clamps - 100
engine and gearbox mounting -500
hydraulic clutch setup - 200
wiring connectors + relays - 100
bolts and other incidentals - 100
dump pipe - 250
exhaust with cat - 600
accelerator cable - 50
catch can setup - 80
battery relocation - 200
radiator and thermos - 600
other stuff you prob will do
good shockers - 600
tyres - 1000
wheels - 300
brake booster - 100
headlight upgrade - 150
Note - a lot of these prices would be roughly what i spent, most items you could easily spend 4 times as much on depending on if you wanted new or better looking etc
Posted on: 2012/5/6 9:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Then factor in engineering and a possible roadworthy certificate to make it legit.
The $1000 engine would be an unknown 2nd hand unit- rebuilding or a rebuilt one will add to that for sure.
Posted on: 2012/5/6 9:25
engineering is $800, if you do the entire list above properly (research first) it shouldn't cost any more than that
Posted on: 2012/5/6 9:30
1200 Coupe Rallycar
That's only through our guy in Vic mic, others charge more and for revisits. Nsw costs more too usually
Posted on: 2012/5/6 9:32
Thanks Mik
He/She hasn't bothered to tell us where they are located
Posted on: 2012/5/6 9:44
1200 Coupe Rallycar
You for got heshes like me.... We have both bases covered
Posted on: 2012/5/6 10:14
I'm at 11g and my cars in 100 pieces not even started
Posted on: 2012/5/6 11:11
Car free
From Brisbane
20g for basic build using maddat gear. Thats not body work either
Posted on: 2012/5/6 11:27
