Re: Master cylinder mod to suit 4 wheel discs
From Melbourne, Australia
nah, took the pin out of the brake pedal and the pedal released up further, so that is not restricting the master rod travel any more
Posted on: 2012/7/10 6:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Oh did you pass sound test too ?
Posted on: 2012/7/10 6:14
lost my patience with this...
left it at the brake place to sort out, they welded up an adjustable pedal rod, considered rebuilding the fronts, then took the second check valve out (so none in front or back)
somewhere in all that and 3 or 4 days later in the end it's not locking up anymore
makes no sense to me, shouldn't have to remove front check valve, even the check valve in the rear had the two grooves in it
i dunno, car fixed, makes no sense, don't car anymore cause it goes again.
Posted on: 2012/7/18 12:43
1200 Coupe Rallycar
good to hear, so still 11/16 mc?
Posted on: 2012/7/18 15:38
« 1 2 (3)
