210/b310/sunny heater core
From Indiana, USA
Anybody know what heater cores will work in place of a stock b310/210 heater core? I see a lot of Datto heater cores on ebay but none for my model. There's one on there for a 310 that looks pretty similar. Cheers.
Posted on: 2012/11/14 16:20
Re: 210/b310/sunny heater core
I doubt if 310 core would work. Heater cores are usually different for every car series.
Your best bet is getting one out of a 210. There are some in wrecking yards from time to time. Helman in Sydney, Ohio has one for $30.
Posted on: 2012/11/15 1:54
From Indiana, USA
I was also once told by someone that you could fashion a heater core just by using a large diameter pipe and making fittings to connect to the water lines. Ya ever tried anything like that? Obviously the heater would pretty much always be going.
Posted on: 2012/11/15 14:50
Time Flies Like An Arrow, Fruit Flies Like A Banana.
yes that does work, although it doesn't shed as much heat. And it won't be on all the time as the valvecock is what controls the flow.
Posted on: 2012/11/15 22:29
im trying to find a way to demist the windscreen in my 79 b310 too.
Posted on: 2012/11/16 7:32
Put the lever to DEFROST and turn on the fan. if that doesn't work then something is broken
I fixed a car Sunday where that didn't work. Turned out the ventilation system was full of water.
Posted on: 2012/11/16 7:56
From Narellan,Sydney
If its only for a dimister buy 1 off eBay.they work ok can be hot or cold and only electric meaning no water in the cabin :)
Posted on: 2012/11/16 8:19
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Indiana, USA
In mine I believe the valve is actually corroded shut. I suppose the whole heater core may not even be bad. I wonder if I can just cut that valve out all together?
Posted on: 2012/11/18 23:59
Yes, if you want 120 degree hot air coming in all the time, just remove the valve and run a hose directly to the core.
You can still buy new 1200 heater cocks, so maybe they still have B310 units avaiable.
Posted on: 2012/11/19 3:33
From Indiana, USA
Fantastic, I don't really mind that, I can always keep the vent door closed when I'm not using it. But hell, if i'm finally going to fix this, even though I don't drive it in the winter, I might as well get me a new AC compressor. The one I have seized up. I don't suppose you know where I can get on of those? :)
Posted on: 2012/11/19 17:14
