1200 Ute grilles
Hey everyone,
So I recently got myself a 1200 Ute. It's been freshly sprayed and everything is in bits at the moment. I've been restoring the chrome trims and I've bought myself a new grille as the old one was crappy.
Problem is that the bottom grille mounts don't line up with the tabs on the body. The top ones line up fine but bottoms are all out by around 30mm or so. I'm sure I've got the right grill (plastic grille) and I even tried to put the old grille back on - same issue.
Could the panel beater have remove and welded the tabs in wrong? Or am I missing something here?
Posted on: 2013/2/10 8:44
Re: 1200 Ute grilles
From Melbourne AUS
anythings possible
what year is your ute? maybe its supposed to have the early metal grille?
Posted on: 2013/2/10 10:37
1973 B110 A12
1971-1978 ute uses the sedan metal grille
1978-1989 ute used the coupe-type plastic grille
1989-up core supports are different yet again
Posted on: 2013/2/10 20:16
Hey guys, yeah it is a 1980 model so as far as I know it should be a plastic grille (which it is).
The tabs are in the same spot as the first setup in the photo although they just don't line up.
Posted on: 2013/2/10 21:42
