Browsing this Thread:
1 Anonymous Users
Re: fuel leak |
Registered Users Contentmaster Usermaster
It should be OK blocked off -- if the fuel pressure is low enough (weber says 2.5 to 3 pounds). Most troubleshooter vacuum gauges can measure fuel pump pressure, so check it! High pressure can cause intermittent issues besides leaking.
If the fuel pressure is ok, put a cap on the brass fitting along with an appropriate size hose clamp.
> Is there anyway I can send the fuel back to the tank?
If you add a return line to the fuel tank, sure.
Posted on: 2013/2/22 8:58
