Re: Need help
> the dash lights Dont work and that alternator lights on
Dash lights should still work even if the alternator is not charging. Sounds like you have two separate problems.
1974 B210, japan built or otherwise, used external voltage regulator. Like cadet said it's possible someone swapped a newer internally regulated model, and also possible that it's not wired correctly.
* Look on the alternator for model number
* Alternator T-connector markings of F and N
* Alternator T-connector markings of L and S
FN type is externally regulated, LS type in internal.
Posted on: 2013/2/24 2:56
Subject Poster Date
     Need help a12datto120y 2013/2/24 2:06
       Re: Need help a12datto120y 2013/2/24 2:18
         Re: Need help cadet1200 2013/2/24 2:44
           Re: Need help ddgonzal 2013/2/24 2:56
       Re: Need help datsunbeginner 2013/2/25 6:48
