SR20DE rocker cover presurizing!
From Sydney Australia
My rocker cover is pressurizing (cant spell sorry) think it might be the PVC valve any info would be appriciated.
Posted on: 2004/4/30 12:30
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: SR20DE rocker cover presurizing!
From Christchurch. NZ
you should have a breather and pcv outlet, with both these clear there should not be pressure in crankcase
Posted on: 2004/4/30 12:33
Cheers I will check tomorow and let you know what happened.
Posted on: 2004/4/30 13:09
If you remove the oil filler cap while the engine is running, it should blow oil droplet out. That is normal.
If you have some other problem, yes, check the previous suggestions.
Posted on: 2004/5/1 17:09
Thanks ddgonzal
When I take the oil cap off when its running it puffs a fair bit of air and a bit of oil and the engine runs noticeably rougher.
There is also a tapping noise consistant with revs (pretty sure its not in the rockers will find out where tomorow)
There is also a bit of oil around the rocker cover seal is that normal?
Posted on: 2004/5/3 11:14
