Gaskets
From Goulburn NSW
Hi guys im looking at buying a tomie head gasket for my ca18det but it is 1mm bigger than the bore,is this ok?
Posted on: 2014/1/29 8:30
Re: Gaskets
Do you mean Tomei?
Posted on: 2014/1/29 9:30
Re: Gaskets
From Goulburn NSW
Yes DD tomei,i was spelling it wrong.
Posted on: 2014/1/29 9:34
Re: Gaskets
Most head gaskets are larger than the bore, including factory gaskets. If you want an optimum gasket, try a Cometic or similar custom gasket.
Posted on: 2014/1/29 9:44
Re: Gaskets
From Goulburn NSW
Hi guys I have another question about head gaskets,im getting my head shaved if it needs it.Now there are 3 different thinknesses of gasket 1.2mm,1.5mm and 2mm,which one should I be looking to buy?
Posted on: 2014/1/30 6:38
Re: Gaskets
If the head does not need shaving, use the 1.5 mm gasket. Or if you want to customize the compression ratio, use either 2.0, 1.5 or 1.2 mm.
Posted on: 2014/1/30 7:28
