Re: Aftermarket Crank angle and tdc sensor??
There is no ignition module in it. Only a rotor and the CAS.
You can presumably retrofit the 4G1 Orion CAS into an E-series distributor.
The CAS in the D4P is apparently the type used by some Mitsubishi V6 engine.
Posted on: 2015/2/10 23:19
Subject Poster Date
     Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/7 9:17
       Re: Aftermarket Crank angle and tdc sensor?? Datman95 2015/2/7 9:48
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 10:24
           Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 10:48
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/7 18:15
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/7 21:19
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/8 3:34
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/8 4:46
         Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/8 8:16
           Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/8 10:27
           Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/10 22:54
             Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/10 23:19
               Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/11 3:05
       Re: Aftermarket Crank angle and tdc sensor?? Zdog85 2015/2/15 5:35
         Re: Aftermarket Crank angle and tdc sensor?? ddgonzal 2015/2/15 8:00
