Re: brakes not working
Ebrahim, I'm not sure what is the symptom
* "If I bleed the back brakes for on my master cylinder with my brake pedal pressed in, the pedal goes down to the floor board"
* "if I try bleeding the back brakes from the master cylinder, then it stays the same"
Can you give more details?
It is common for 1) a new master cylinder to be defective and 2) for the master cylinder pushrod to need adjustment
Posted on: 2015/4/24 18:09
Subject Poster Date
     brakes not working ddgonzal 2015/4/24 18:02
       Re: brakes not working ddgonzal 2015/4/24 18:09
