Re: A12 in a 1964 MG Midget
Not too shy to talk
Through research, I found that it's a Triumph manifold with, I believe, H4S carburetors. I was able to find that the port holes are the same as my A12 (approximately 1 inch) but I couldn't find what the distance was between the holes. If it's close, this is the route I'll take.
Any Triumph experts?
Posted on: 2016/1/8 2:16
Quite a regular
Ive sent you a PM...I cannot get a pic up here but can email one.
Posted on: 2016/1/8 2:38
Not too shy to talk
Thanks to Dave, I won't have to hack the Datsun and MG manifolds! All the way from Australia, a perfectly fitting manifold to mount my MG SU carburetors to.
Posted on: 2016/2/8 3:08
Wow that's different. Are they 1-1/4" SUs?
jpg  IMG_0473.JPG (47.43 KB)
174_56b91cfe07f25.jpg 640X480 px
jpg  IMG_0474.JPG (44.29 KB)
174_56b91d111cc24.jpg 480X640 px
Posted on: 2016/2/8 22:56
Not too shy to talk
Yes, 1-1/4". I will need to extend the linkages shared between the carburetors and possibly make a new heat shield.
Posted on: 2016/2/9 1:16
Quite a regular
Great to see it being used instead of sitting in my shed :)
Posted on: 2016/2/9 4:49
Not too shy to talk
I am in the process of having my MG painted so, the Datsun equipment hasn't received much attention. However, I should be making some engine and transmission progress soon.
I will be getting custom gauges from SpeedHut that match the original MG Smiths gauges but I was wondering what the orange and red lines should be adjusted at for the A12 motor. Any thoughts?
Posted on: 2016/3/1 3:36
It depends on the camshaft you have chosen and especially the valve springs -- where does valve float begin?
* The yellow zone should start at 6000 RPM, unless you have fitted a mild cam then it should be 5600 RPM
* The red zone starts at 6400 RPM with stock Datsun valve springs. 6800 with Datsun GX valve springs, or higher with aftermarket valve springs
jpg  smiths.jpg (39.34 KB)
174_56d512610123c.jpg 600X450 px
Posted on: 2016/3/1 3:52
Here is the stock Datsun 1200 tachometers
Datsun 1200 - 6400 redline
Datsun 1200 GX - 6800 redline
Posted on: 2016/3/1 5:33
Not too shy to talk
Does anyone know where I can find a transmission cover plate?
Posted on: 2016/3/14 2:26
« 1 2 (3) 4 5 »
