Easiest way to change intake manifold gasket A14?
Do I have to pull the exhaust manifold? What would be the easiest way?
Posted on: 2016/6/4 8:25
Re: Easiest way to change intake manifold gasket A14?
The manifold gasket is 1-piece and is for both the intake & exhaust -- so you won't be changing the "intake" gasket, but the combo manifold gasket
You do not need to "pull" the exhaust manifold -- be sure to leave it attached to the intake manifold if it's the connected type. But in either case you do have to unbolt it from the head. Then pull the manifolds out away from the head, scrape the surfaces clean, slip the new gasket in, and torque it up
Posted on: 2016/6/4 8:48
It's fairly easy to change the manifold gasket -- except for the four lower bolts that fasten the intake to the head. They are difficult to see:
I use a socket on a wobbly extension (12 mm socket)
Posted on: 2016/6/4 9:03
