Ea falcon alternator
From Sydney, NSW
Hi all just wondering if this is the right one to suit the upgrade?
ea falcon alternator
Posted on: 2016/8/7 23:16
Re: Ea falcon alternator
From Melbourne, Australia
Yeah looks right. Ive done it a couple of times.
Posted on: 2016/8/8 1:48
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, NSW
So do you have a spacer or something on the back half?
Thanks,
Tom
Posted on: 2016/8/8 1:52
That one on eBay looks like a Bosch Australia unit, like the ones fitted to aus-assembled 120Y
It also looks like it is internally regulated? If so minor wiring change might be needed
Posted on: 2016/8/8 5:17
From gold coast QLD.
If anyone is interested,I had to change alternators to run all the electrics associated with turbo fuel injection and I used a Nissan Patrol unit,only req'd a pulley downgrade back to the standard one.
Posted on: 2016/8/8 7:19
Hi bert, what year Patrol? Maybe was a Hitachi LT160, 60A version of the 1200 LT135 35A alternator, about 1" bigger around
Posted on: 2016/8/8 7:38
From Sydney, NSW
Heya Bert! any idea on the model?
pulley downgrade on what? the alternator?
What efi inlet etc are you running?
Posted on: 2016/8/8 7:44
Theres 3 different datsun 1200 mounts. So depends what you have how you have to modify it. And yes its inernal reg so you have to change wiring to suit.
Easiest one to mount is if your 1200 has the cast mount on the drivers side. You can just grind it down on the back side to suit. If you have the steel folded plate style mount then you use spacers
Posted on: 2016/8/8 13:45
1200 Coupe Rallycar
From Sydney, NSW
Just wondering if you can tell if I'd need a spacer or what the best way to mount the EA alt would be?
Posted on: 2016/8/8 14:44
Edited by thomen on 2016/8/8 22:00:18
Yes, you have a Late A-series (alternator goes on right side of engine). Late means 1974 or newer. On the early engines, alternator was on left side
You also have the cast iron mount bracket, so as 1200rallycar says, grind the bracket on the rear portion so that it fits the Bosch. Or you could use a Hitachi, which is 60A bolt-on (from most 1980s Nissan). Either is a big upgrade from the 35A Datsun unit
EA Alternator Vs 1200 Alternator
Posted on: 2016/8/8 22:45
(1) 2 3 »
