Re: Rating Rear Leaf Springs
Good point, measuring is the way. They say that Leafs don't lose spring rate over time, although they do sag (resulting in less camber, which affects the load capacity). They can be cold-reset to alter or restore the camber
* rear Spring Rate is 109 lbs/in for a stock 1200 sedan or coupe
* stock leaf spring pack camber is 109mm +- 3mm
* rear Spring Load appears to be 468 lbs
Posted on: 2016/12/19 9:05
Subject Poster Date
     Rating Rear Leaf Springs B110SSS 2016/12/17 2:39
       Re: Rating Rear Leaf Springs ddgonzal 2016/12/17 3:04
         Re: Rating Rear Leaf Springs datsa73 2016/12/19 3:39
           Re: Rating Rear Leaf Springs ddgonzal 2016/12/19 9:05
       Re: Rating Rear Leaf Springs B110SSS 2016/12/19 5:11
