Help identify R31 diff
From Sydney, Australia
Hi Guys,
I picked up a r31 diff recently, however not sure the type of it.
Can someone please help me identify it?
It has a 9-bolt rear cover and 6-bolt tailshaft flange
Thanks in advance :)
Kind regards
Ron
jpg  Capture.JPG (68.08 KB)
18758_59e5c081923c5.jpg 638X484 px
jpg  Capture2.JPG (47.98 KB)
18758_59e5c08adf56c.jpg 598X208 px
Posted on: 2017/10/17 9:37
Re: Help identify R31 diff
9-bolt cover is fairly unique - it is a Borg Warner 78. If it really came from an AUS-built R31, it could have either the 25 spline (R31 Pintara) or 28 spline (R31 Skyline) axles
You can confirm if the 3.89 ratio is still in there by examining the numbers stamped on the crown wheel (ring gear). Divide the two numbers
The 28-spline unit is rated for 320 ft. lb. torque, about what a 5.0 V8 puts out
Posted on: 2017/10/17 9:58
Thanks dd,
Is there a way to tell if it is a 28 spline or 25 spline??
Kind regards,
Ron
Posted on: 2017/10/17 10:04
From Perth
3.89 is the Skyline ratio... so should be 28
Posted on: 2017/10/17 12:00
