Re: HELP NEEDED - EFI ECU options for turbo A15
From Mordialloc Victoria 3195
+1 for what DD said ( Microsquirt/megasquirt )
Your TUNER will tell you which one he likes to use. Keep him happy
If your tuner is familiar with Microsquirt ( SIMPLEST and CHEAPEST )
then I can recommend it - has been working on mine fine for years
If your on a budget then your probably going to run a 'simple as possible'
system so the more expensive ecu's will have a huge amount of options that your
not ever going to use.
I/we ( acknowledge the tuner ) didn't use half the options(wires) available on the
microsquirt)
Just my 2 cents
dp
Posted on: 2019/5/7 22:08
keep it simple
Subject Poster Date
     HELP NEEDED - EFI ECU options for turbo A15 scrubba620 2019/5/7 7:39
       Re: HELP NEEDED - EFI ECU options for turbo A15 ddgonzal 2019/5/7 8:00
         Re: HELP NEEDED - EFI ECU options for turbo A15 Mattndew76 2019/5/7 10:57
           Re: HELP NEEDED - EFI ECU options for turbo A15 dattoman_1000 2019/5/7 11:59
             Re: HELP NEEDED - EFI ECU options for turbo A15 zigmondo 2019/5/7 22:08
               Re: HELP NEEDED - EFI ECU options for turbo A15 ddgonzal 2019/5/9 2:54
       Re: HELP NEEDED - EFI ECU options for turbo A15 zigmondo 2019/5/10 23:04
         Re: HELP NEEDED - EFI ECU options for turbo A15 D 2019/5/11 6:07
