CA18 install questions, easy ones :-)
From Melbourne, Australia
ive read a million times that people are using CA20 bell housings and skyline stumpy boxes behind them
which CA20 is the bell from
and which skyline the box from exactly
(post for someone else )
thanks fellas
Posted on: 2005/3/3 11:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18 install questions, easy ones :-)
From Sydney, Australia
Series 3 Bluebird with CA20.
R30 Skyline (L24 power) 5 speed.
Might need a different sized bearing to help it all mate up. I've heard of people matching a CA18DET front casing with the L24 R30 Skyline g/box.
Posted on: 2005/3/3 11:18
From Melbourne Vic
yes, yes and... yes. need a different bearing. daveman posted the part number up about a month ago.
Posted on: 2005/3/3 12:24
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Not too shy to talk
From Narre Warren Vic
Any reason why no one has used the box out of the r31 pintara.Also is the flywheel from the ca20 a bolt up for the ca18. this is not for a 1200 so bulk is'nt a prob, but length could be.
Posted on: 2005/3/4 0:19
668 the neighbour of the beast
From Melbourne Vic
if you're talkin about the CA20 pintara box, its the same as the CA20 bluebird box. they work, just not very strong. they only back a 2 litre four remember.
not sure on the flywheel, but the box would work if you didn't have a heap of power behind it and treated it verrry nicely.
Posted on: 2005/3/4 0:43
Not too shy to talk
Thanx lagy, I intend this to back a turbo'd de evetualy so that info is tops .
Posted on: 2005/3/4 3:57
The CA20 flywheel and front pulley are wimpy and different to the CA18DE/DET.
The CA20 is like an asthmatic, calcium deficient, overweight big brother..might be bigger, but not as fast.
Regards,
Chris
Posted on: 2005/3/4 4:31
From sydney
Bit of topic but
I used to run a stock CA20 gearbox behind my FJ20T bolted straight up cost me a six back of beer and never missed a beat.
The reason i tried it was because i was told that it is identical to the FJ20T box the only thing was 4th gear was i bit smaller.
Posted on: 2005/3/4 5:05
Not too shy to talk
Thanx for that dood .By smaller 4th gear,do you mean that 5th was an obvious overdrive rather than a well spaced next gear.Anyone else got experiance with these boxes?
Posted on: 2005/3/4 22:32
Not too shy to talk
BUMP
Posted on: 2005/3/7 6:35
