Re: SR20DE
From Stray-ya
I'd be keen to get a bit more info on this topic as well. I have only seen the SR20VE Neo in FWD format. If it could be adapted to RWD it would be a ripper conversion (assuming you could get one for a reasonable price)
Is the FWD block the same as the RWD?
Could the crank angle sensor from the CA or something else be used? (probably not the CA cos it would be rotating the wrong way)
How difficult/expensive is it to get a plenum reversed?
Apart from all those hassles, the FWD SR20's are 108kW instead of 120 so unless you had a NEO it wouldnt be worth the trouble
Posted on: 2005/6/27 7:53
Subject Poster Date
     SR20DE datsun120ycoupe 2005/6/26 3:54
       Re: SR20DE datsun120ycoupe 2005/6/26 5:13
         Re: SR20DE b310gx 2005/6/27 2:39
           Re: SR20DE Grunterhunter 2005/6/27 7:53
             Re: SR20DE datsun120ycoupe 2005/6/27 8:18
               Re: SR20DE datsun120ycoupe 2005/6/27 9:48
               Re: SR20DE Ash 2005/6/27 9:56
                 Re: SR20DE Mr_Turbo 2005/6/27 10:30
                   Re: SR20DE datsun120ycoupe 2005/6/28 6:16
                     Re: SR20DE Ash 2005/6/28 9:05
                       Re: SR20DE datsun120ycoupe 2005/6/28 9:10
                         Re: SR20DE converted 2005/6/28 13:03
                           Re: SR20DE independentslider1 2005/6/28 14:18
                             Re: SR20DE matbighat 2005/6/29 2:49
                               Re: SR20DE tens_and_twenties 2005/6/29 3:37
                                 Re: SR20DE tappet 2005/6/29 4:10
                                   Re: SR20DE datsun120ycoupe 2005/6/29 7:52
                                     Re: SR20DE Grunterhunter 2005/6/29 8:00
                                       Re: SR20DE datsun120ycoupe 2005/6/29 9:00
                                       Re: SR20DE datrat_dave 2005/6/29 9:03
                                       Re: SR20DE dattodevil 2005/6/29 9:03
                                         Re: SR20DE datsun120ycoupe 2005/6/29 10:20
                                           Re: SR20DE Grunterhunter 2005/6/29 11:02
                                             Re: SR20DE dattodevil 2005/6/29 11:50
                                               Re: SR20DE dattodevil 2005/6/29 12:02
                                               Re: SR20DE tappet 2005/6/29 14:18
                                                 Re: SR20DE datsun120ycoupe 2005/6/30 10:22
                 Re: SR20DE Grunterhunter 2005/6/27 10:35
