Re: Idle Screw ??
From Brisbane
1st Check for air leaks in the Booster, Inlet Manifold and Carby, also check the Distibutor that the vacuum advance is working. Check for any broken gaskets or hoses that lead from the carby or Inlet manifold... When all are fixed then you can tune it properly.
See the only leak your allowed to have is through the Butterfly valve and any air coming from anwhere else is bad news, it means your car will run out of tune.
Posted on: 2002/10/7 14:28
Subject Poster Date
     Idle Screw ?? amshaw 2002/10/7 9:51
       Re: Idle Screw ?? cleaner 2002/10/7 11:38
       Re: Idle Screw ?? andos 2002/10/7 11:46
       Re: Idle Screw ?? Dragongoose 2002/10/7 14:28
         Re: Idle Screw ?? dimlight65 2002/10/7 15:00
       Re: Idle Screw ?? ang94541 2002/10/7 23:36
         Re: Idle Screw ?? ddgonzal 2002/10/8 4:45
           Re: Idle Screw ?? amshaw 2002/10/8 6:14
             Re: Idle Screw ?? amshaw 2002/10/9 2:46
               Re: Idle Screw ?? andos 2002/10/9 3:14
                 Re: Idle Screw ?? amshaw 2002/10/9 3:26
                   Re: Idle Screw ?? 1200rallycar 2002/10/9 3:31
                     Re: Idle Screw ?? 1200rallycar 2002/10/9 3:35
                       Re: Idle Screw ?? amshaw 2002/10/9 3:42
                   Re: Idle Screw ?? ang94541 2002/10/9 6:43
                     Re: Idle Screw ?? 1200rallycar 2002/10/9 10:01
                       Re: Idle Screw ?? Dragongoose 2002/10/9 16:10
             Re: Idle Screw ?? ddgonzal 2002/10/10 4:19
               Re: Idle Screw ?? amshaw 2002/10/10 8:13
                 Re: Idle Screw ?? amshaw 2002/10/10 12:43
                   Re: Idle Screw ?? RICLAGE 2002/10/10 13:45
                     Re: Idle Screw ?? Dragongoose 2002/10/10 17:09
                       Re: Idle Screw ?? dimlight65 2002/10/10 19:39
                         Re: Idle Screw ?? ddgonzal 2002/10/11 3:00
                           Re: Idle Screw ?? amshaw 2002/10/25 12:16
