Need help about Mikuni PHH40..
From Selangor, Malaysia
Hi Guys,
need an advice..i'm facing a problem where one of my carbies it's not working well as it supposed,when i closed the A carburetor's mouth,pulled the cable plug 1&2 the engine is still running but vice versa on the carburetor B..so i can tell the engine is only running with carb B..but it runs worst
**carb A is for cylinder 1&2
**carb B is for cylinder 3&4
the symptoms that i'm facing:-
1. when idling,it produced a boxer sound
2. backfire at the carby and exhaust too
i've changed the gasket and also the position of the carbies,and yet only one that working fine which is carb B..it seems like the carb A is not feeding the engine with the fuel..
What is the problem?i'm totally have no idea..please shed some light..
Many Thanks.
Posted on: 2010/2/20 14:55
dying to learn A series..help me :)
Re: Need help about Mikuni PHH40..
Start with the basics.
1. Compession test
2. Timing check
If it still has a problem after this, swap the carbs and see if it changes to 3&4 not working.
Posted on: 2010/2/20 17:05
hi dd,
i've done the basic check as u said,the compression and timing is ok..
and once i swapped it,the problem is still there, affecting the 3&4 cylinder vice versa to cylinder 1&2..
Posted on: 2010/2/21 2:42
Thus, open the carburetor and inspect it. something loose? something missing? something incorrect?
Posted on: 2010/2/21 7:36
From Kuala Lumpur, Malaysia
try checking throttle linkage...make sure the carb butterfly sync....
Posted on: 2010/2/22 12:31
