A15 runs great but it stops running at random!?!?
I was running my A15 for 1hour and 30min the other day and for the most part it runs great! As I was running it it has a big problem! It it almost stalls and random times! In that hour and a half it tried to stall on me 5 times. I don't get it?!?!
Any ideas?
God Bless
~Matt~
Posted on: 2012/1/28 18:08
Re: A15 runs great but it stops running at random!?!?
Most common cause: Fuel filter pluged or loose fuel line causing air to draw into pump. Possibly crud in the fuel.
2nd most common: Contact Points set in the distributor is no adjusted correctly. Replace every 12 months/12,000 miles. Dunno how many hours that relates to in a stationary engine.
Posted on: 2012/1/28 20:14
From Malaysia
when your engine stall, try to touch your ignition coil. it shouldn't be hot. if it is hot or very warm, replace it.
Posted on: 2012/1/28 22:05
From Sydney.au
i had the exact same problem a few years ago and it turned out to be bad wiring to my battery GND terminals (or 12V) cant remember. Either way it confused me a lot until i actually traced it all from the battery to its relative places and found some crap wiring. Upon repairing, the beast was perfect again.
edit: with my problem, obviously, the entire 12v rail would be gone. everything would cut out, incl the engine.. lights, dash lights everything..
edit: yeh everything would cut out ; everything! if your motor is still idling then goes back to normal rev's (when you hit the throttle) then like other members said its likely a fuel delivery problem. goodluck!
Posted on: 2012/1/28 23:10
Edited by evilsim on 2012/1/31 6:43:30
"Most common cause: Fuel filter pluged or loose fuel line causing air to draw into pump. Possibly crud in the fuel.
I changed the filter. As for the fuel line, I will have a look:)
I don't think the contect points can be adjusted. It's electric. I could totally be wrong because I don't really know what I'm doing!
Posted on: 2012/1/29 0:20
I will do that:) Thanks!
Could that cause this problem? It never totally dies out. It just sputters then goes right back up to the rpm's I set it at.
Posted on: 2012/1/29 1:19
I will follow wiring to see if that will do the trick. The wiring around the battery looks bad. When you say everything would cut out do you mean it would totally die? My motor keeps going like it going to stall but then it goes right back to normal. I don't need to restart. Let me know please:)
Posted on: 2012/1/29 1:25
There are many things that can cause your symptoms. But it is less likely to be electrical (or it would be more erratic), and more likely to be fuel related.
Did it start occuring about the time you replaced the fuel filter?Or what else changed around that time it first started happening?
Posted on: 2012/1/29 2:03
could be the anti dieseling solenoid in the side of carb as shown in picture. i had an issue with it wanting to stall randomly and traced it down to that.
jpg  15572.jpg (17.51 KB)
11951_4f24ad66b2b8d.jpg 464X208 px
Posted on: 2012/1/29 2:21
You can easily test that theory. By disconnect the idle-cut solenoid internally. See anti-diesel valve.
Posted on: 2012/1/29 2:28
